Server error - server unavailable
Webonique
Webonique posted this 14 December 2015
Is there a solution for this bug jet??????????????
11 Comments
info1662
info1662 posted this 14 December 2015
I have the same problem. I cannot edit my templates since this error. It seems that it depends from the last update.
Webonique
What I do now: I go to themler.com and go to download online.
There I get my template, adjust it and download a new zip and install it in joomla!
I know it isn't the way it should be but untill they finally fix this bug it is my only way!!!!!
What I do now: I go to themler.com and go to download online. There I get my template, adjust it and download a new zip and install it in joomla! I know it isn't the way it should be but untill they finally fix this bug it is my only way!!!!!
LGWeb
LGWeb posted this 14 December 2015
Same here..
Same here..
LGWeb
I have the zip file installed to a live Wordpress Site.. I can't make edits in Themler.. Server Unavailable.
Webonique
Webonique posted this 15 December 2015
But you made it in Themler?? Then you must have downloaded the zip-file
So it must be in your themes....
But you made it in Themler?? Then you must have downloaded the zip-file So it must be in your themes....
Marco
Marco posted this 15 December 2015
This f*** Problem should be fixed instantly!
It could not be, that i need to give access to my pages (the problem exists on more then 7 pages, yet!)
This f*** Problem should be fixed instantly! It could not be, that i need to give access to my pages (the problem exists on more then 7 pages, yet!)
Support Team posted this 16 December 2015
Hi guys,
Sorry for the delay.
We investigated this issue properly.
Now everything should work fine.
Could you please try to reproduce the issue and let us know the result.
We're waiting for your feedback.
Ivan
Hi guys, Sorry for the delay. We investigated this issue properly. Now everything should work fine. Could you please try to reproduce the issue and let us know the result. We're waiting for your feedback. Thanks, Ivan
Webonique
Webonique posted this 16 December 2015
Haleluja! It is working again! Saves me a lot of work and tears!
Marco
Marco posted this 17 December 2015
japp. can confirm, too...
works fine again...
japp. can confirm, too... works fine again...
rickard2
rickard2 posted this 13 April 2016
I have this issue constantly now last couple of days.
Please create a separate private topic with the access to your site back end so we could investigate the issue.
Hi, Please create a separate private topic with the access to your site back end so we could investigate the issue. Sincerely, Hella
