artisteer annual license
hoseinqadimi
hoseinqadimi posted this 15 December 2015
I've bought artisteer annual license.
Can I use the same license on themler?
0602-CAED-BBC4-0D93-CD2B
Hello I've bought artisteer annual license. Can I use the same license on themler? 0602-CAED-BBC4-0D93-CD2B
Support Team posted this 15 December 2015
Yes, for this please enter your Artisteer license code into the field on http://themler.com/Purchase. Then select one of Themler subscription options available for your license and enable Themler subscription.
Hello, Yes, for this please enter your Artisteer license code into the field on http://themler.com/Purchase. Then select one of Themler subscription options available for your license and **enable** Themler subscription. Sincerely, Nettie, BillionDigital Team
ahmedsaifan
ahmedsaifan posted this 16 December 2016
Hi ,
i tried what you said but i get message that the serial number already in use !!! , i actually use it to activate the artisteer 3.4 , so whenever i try to export by the themler it asks to choose the drupal license ?! while my subscription would expires after a year " 01-2018"
Hi , i tried what you said but i get message that the serial number already in use !!! , i actually use it to activate the artisteer 3.4 , so whenever i try to export by the themler it asks to choose the drupal license ?! while my subscription would expires after a year " 01-2018"
Please provide more details about what you are trying to export. You can export the HTML, WP and Joomla themes. Drupal export plug-in should be purchased separately.
Hi, Please provide more details about what you are trying to export. You can export the HTML, WP and Joomla themes. Drupal export plug-in should be purchased separately. http://themler.com/Purchase Sincerely, Hella
david.toohey
david.toohey posted this 01 March 2017
I am also trying to use Themler (with DNN) as Artisteer is simply no good any more and maybe Themler is a bit better. License code 0601-EEF7-2406-72BC-65A9 says it is already in use.
Support Team posted this 01 March 2017
Hi David,
May I ask you to create a new private ticket so we could try to help you there.
Ivan
Hi David, May I ask you to create a new private ticket so we could try to help you there. Thanks, Ivan
