Please make the sidebar to be able to be page width
shaulhadar
shaulhadar posted this 10 December 2014
Hello Themler Team. Please make that we can make the sidebars be 100% page width. Currently it defaults to content width, and no option to change it.
If the sidebar was 100% page width, i could use for instance, revolution slider on whole of the page, but currently now i can't do it.
Shaul.
Hello Themler Team. Please make that we can make the sidebars be 100% page width. Currently it defaults to content width, and no option to change it. If the sidebar was 100% page width, i could use for instance, revolution slider on whole of the page, but currently now i can't do it. Thanks, Shaul.
Support Team posted this 10 December 2014
Hello Shaul,
in fact you may create such sidebar.
Locate Row control outside Sheet and set its Length to Full Page:
The Row should have 1 column. Locate Primary Widget Area control inside Column and it will be the page width too:
Hello Shaul, in fact you may create such sidebar. Locate Row control outside Sheet and set its Length to Full Page: !FullPageRow.png! The Row should have 1 column. Locate Primary Widget Area control inside Column and it will be the page width too: !WidgetArea.png! Regards, Aileen
shaulhadar
shaulhadar posted this 11 December 2014
Hi Aileen, that's great!
Hi Aileen, that's great! Thanks :)
Support Team posted this 11 December 2014
Hi Shaul,
have a good day!
Helen
Hi Shaul, have a good day! Helen
Support Team posted this 12 December 2014
Actually, you probably need one more option that is not implemented yet.
Because currently only background is full page, but not content.
Actually, you probably need one more option that is not implemented yet. Because currently only background is full page, but not content. ? !full-background.png!
