"Sorry, error occurred. Your project will be restored -Endless loop
faithbloom
faithbloom posted this 27 December 2015
When I load Themler from Joomla template edit it says this.
"Sorry, error occurred. Your project will be restored" after click on "Ok" button,
system repeat the same screen.....and keeps restarting and loop offer the same error message ?
It is same on Firefox and Chrome
Some guy already reported this but disappeared and can only be seen in the Google search cache.
Please I am on tight deadline, pleas
When I load Themler from Joomla template edit it says this. "Sorry, error occurred. Your project will be restored" after click on "Ok" button, system repeat the same screen.....and keeps restarting and loop offer the same error message ? It is same on Firefox and Chrome Some guy already reported this but disappeared and can only be seen in the Google search cache. Please I am on tight deadline, pleas
28 Comments
steve38
steve38 posted this 27 December 2015
I get the same with one of my joomla therms, it was originally imported from Artisteer and now seems unusable in the desktop Themler, but it will open as edit template from of the live joomla site
rharkonen
rharkonen posted this 27 December 2015
I have the same thing happening with my Wordpress website. I cannot do anything now with Themler as it is stuck in an endless loop.
rharkonen
I have been playing with it and found that if I add wp-admin/themes.php?page=theme_editor&theme=ThemeName&ver=130 to it I can access it using the old interface. I have to enter it every time though to access it. Still not a fix, but at least I can work on it.
I have been playing with it and found that if I add wp-admin/themes.php?page=theme_editor&theme=ThemeName&ver=**130** to it I can access it using the old interface. I have to enter it every time though to access it. Still not a fix, but at least I can work on it.
Support Team posted this 28 December 2015
Hi guys,
Sorry for the issues.
In order to help you we need to access your back-end to reproduce the issue firstly.
Please create new private tickets and provide us with the necessary credentials to access your back-end.
Ivan
Hi guys, Sorry for the issues. In order to help you we need to access your back-end to reproduce the issue firstly. Please create new private tickets and provide us with the necessary credentials to access your back-end. Thanks, Ivan
faithbloom
faithbloom posted this 28 December 2015
Please check private ticket 51845.
I need to know how this is fixed as the main development is on Xamp on my local machine. I just put up a copy of the project so that you can investigate this.
Hi guys,
Ivan
Please check private ticket 51845. I need to know how this is fixed as the main development is on Xamp on my local machine. I just put up a copy of the project so that you can investigate this. > Hi guys, > > Sorry for the issues. > In order to help you we need to access your back-end to reproduce the issue firstly. > > Please create new private tickets and provide us with the necessary credentials to access your back-end. > > Thanks, > Ivan
rharkonen
rharkonen posted this 28 December 2015
I gave mine a try again today and it seems to have updated now. Don't know why or if it was something I did.
faithbloom
faithbloom posted this 29 December 2015
This is still not working for me. My work has stalled.
info2015
info2015 posted this 01 January 2016
Go to your article(s) trough the backend. Check your text in the articles for codes that shouldn't be there. Delete the codes.
Thats all :). you now can work with themler cms again.
sorry for my bad english.
> This is still not working for me. My work has stalled. Go to your article(s) trough the backend. Check your text in the articles for codes that shouldn't be there. Delete the codes. Thats all :). you now can work with themler cms again. sorry for my bad english.
rodolfo.rb
rodolfo.rb posted this 21 January 2016
Hi i have the same problem, what can i do?
Support Team posted this 22 January 2016
Could you please create a separate private ticket with the access to your site where we could see the issue.
Hi, Could you please create a separate private ticket with the access to your site where we could see the issue. Sincerely, Hella
DaveOzric
DaveOzric posted this 08 April 2016
I can't edit any posts and get this error. This is the dead end with no solution? Could use some help.
I can't edit any posts and get this error. This is the dead end with no solution? Could use some help. Thanks
DaveOzric
I can't even open the post template without getting this error, then it reloads to the homepage template.
Hello Dave,
if you get the error
please submit a new private topic and provide access to your CMS admin back end. This is the common error messages, it may have number of different reasons.
Hello Dave, if you get the error "Sorry, error occurred. Your project will be restored" please submit a new private topic and provide access to your CMS admin back end. This is the common error messages, it may have number of different reasons. regards, Aileen
adiemus
adiemus posted this 14 May 2016
This error is happening with themler on my desktop machine. I upgraded wordpress and this is what happened afterwards.
Support Team posted this 16 May 2016
adiemus,
Does the issue happen with a specific theme only or with any Themler theme including default one?
**adiemus**, Does the issue happen with a specific theme only or with any Themler theme including default one? Sincerely, Nettie, BillionDigital Team
Ricardo Martins
Ricardo Martins posted this 09 June 2016
It's happening all the time with a html5 project.
Is there any log or something to see the error?
In the meantime, I've opened a private issue (83988) with more details and screen recording.
It's happening all the time with a html5 project. Is there any log or something to see the error? In the meantime, I've opened a private issue (83988) with more details and screen recording.
Lakeasha
Lakeasha posted this 17 June 2016
I am now having this issue to when trying to update my slide show via themler.
Support Team posted this 17 June 2016
Lakeasha,
Please create a new private case and provide temporary access to your website for investigation. Also please provide exact steps to reproduce the issue.
**Lakeasha**, Please create a new private case and provide temporary access to your website for investigation. Also please provide exact steps to reproduce the issue. Sincerely, Nettie, BillionDigital Team
Gwe Cambrian Web
Gwe Cambrian Web posted this 15 August 2016
Hi, have the same issue & Opened a private question with information.
Cheers,
Emlyn
Hi, have the same issue & Opened a private question with information. Cheers, Emlyn
Support Team posted this 15 August 2016
Hi Emylin,
Thanks for this. We continue our communication on the issue in the private ticket.
Hi Emylin, Thanks for this. We continue our communication on the issue in the private ticket. Sincerely, Nettie, BillionDigital Team
