Lighbox view of images from section
dan224
dan224 posted this 29 December 2015
I would like to create a section containing a grid of images that when clicked on would display the original images via the lightbox. I see how images in the content area or a post are viewed via the lightbox, but how to I make an image added to a section or module do the same?
This is for a basic image gallery. If this is not possible I would HIGHLY recommend adding this feature since image galleries are one of the most common aspects of a website.
Thanks!
I would like to create a section containing a grid of images that when clicked on would display the original images via the lightbox. I see how images in the content area or a post are viewed via the lightbox, but how to I make an image added to a section or module do the same? This is for a basic image gallery. If this is not possible I would HIGHLY recommend adding this feature since image galleries are one of the most common aspects of a website. Thanks!
Support Team posted this 04 January 2016
Hello Dan,
now the lightbox option is available for the Post Images only.
If you want to add lightbox for the Image control (static image) you may look for ready solution and we'll help you to incorporate it into Themler theme.
Hello Dan, now the lightbox option is available for the Post Images only. If you want to add lightbox for the Image control (static image) you may look for ready solution and we'll help you to incorporate it into Themler theme. regards, Aileen
Webnoesys IT Solutions LLP
Webnoesys IT Solutions LLP posted this 31 August 2016
Hi Dan,
I need similar solutions Gallery control for Themler THML Template.
Can we use the Light box image gallery from third party.
For Example - http://visuallightbox.com/jquery-image-lightbox.html
Please let us know ASAP.
Reards
Suffian Ahmed
Hi Dan, I need similar solutions Gallery control for Themler THML Template. Can we use the Light box image gallery from third party. For Example - http://visuallightbox.com/jquery-image-lightbox.html Please let us know ASAP. Reards Suffian Ahmed
Support Team posted this 31 August 2016
You can try to integrate the gallery, the additional code for the HEAD section can be added under the Home >> Settings tab.
Hi, You can try to integrate the gallery, the additional code for the HEAD section can be added under the Home >> Settings tab. Sincerely, Hella
Webnoesys IT Solutions LLP posted this 28 March 2017
Hi Aileen,
Can you provide some templates / sections with jquery animations like numbering rotation, images gallery, scrolling gallery etc
Suffian Ahmed
Hi Aileen, Can you provide some templates / sections with jquery animations like numbering rotation, images gallery, scrolling gallery etc Regards Suffian Ahmed
Support Team posted this 29 March 2017
Hello Ahmed,
I'm sorry but there's no such examples of Themeler themes and sections for HTML available now. However if you find a sample solution for HTML site we'll help you to incorporate it into Themler theme.
Hello Ahmed, I'm sorry but there's no such examples of Themeler themes and sections for HTML available now. However if you find a sample solution for HTML site we'll help you to incorporate it into Themler theme. Regards, Aileen
