Headline styles H1 - H6: before/after space adjustment not shown in preview
Jan-Willem
Jan-Willem posted this 31 December 2015
Cost me some time to figure out what was going on... I tried to remove the white space after the headline H4 by setting space after in the paragraph settings of the main style H4 to zero. Did not see any change.
After playing around with manual added CSS styles I found out the "Space after" is working, but need to publish the theme to my wordpress site to see it working. I.e. it is not shown in the themler preview. Tried it with H3 and H4, so suppose it is not working for all the headline styles.
Can you fix this?
Cost me some time to figure out what was going on... I tried to remove the white space after the headline H4 by setting space after in the paragraph settings of the main style H4 to zero. Did not see any change. After playing around with manual added CSS styles I found out the "Space after" is working, but need to publish the theme to my wordpress site to see it working. I.e. it is not shown in the themler preview. Tried it with H3 and H4, so suppose it is not working for all the headline styles. Can you fix this?
Aleh
Aleh posted this 31 December 2015
Just tried with WP and it works.
See image below. Click to enlarge and see full size image.
Or do you have problems with specific section, not Theme Styles settings?
Just tried with WP and it works. See image below. Click to enlarge and see full size image. Or do you have problems with specific section, not Theme Styles settings? !paragraph.png!
Aleh
if you want to change H1-H6 space for specific Section Control, just click into this control and change padding:
if you want to change H1-H6 space for specific Section Control, just click into this control and change padding: !paragraph2.png!
