Multi language slider or text in themler for Prestashop
WALLOON
WALLOON posted this 10 January 2016
I read this question :
http://answers.themler.com/questions/44778/multi-language-slider-or-text-in-themler
Can I use this technique to create multilingual support in Pretashop too ?
On an other topice - i see WP Widget with multilingual support - is it possible to use such widget in Prestashop ?
Could you give me the correction direction to goes further in multilingual support with Themler in Prestashop?
Many thanks and congratulations for the great product !
Remy
I read this question : http://answers.themler.com/questions/44778/multi-language-slider-or-text-in-themler Can I use this technique to create multilingual support in Pretashop too ? On an other topice - i see WP Widget with multilingual support - is it possible to use such widget in Prestashop ? Could you give me the correction direction to goes further in multilingual support with Themler in Prestashop? Many thanks and congratulations for the great product ! Remy
Support Team posted this 11 January 2016
You can use the Prestashop modules for translations. Also you can refer to the following article on how to use custom templates in Prestashop:
http://answers.themler.com/articles/25838/how-to-use-custom-templates-in-prestashop
Hi, You can use the Prestashop modules for translations. Also you can refer to the following article on how to use custom templates in Prestashop: http://answers.themler.com/articles/25838/how-to-use-custom-templates-in-prestashop Sincerely, Hella
gael
gael posted this 27 November 2017
I use PS 1.6
How can i translate text on slider ? The way you propose is for CMS page, I would like for translate home page... ?
Hi, I use PS 1.6 How can i translate text on slider ? The way you propose is for CMS page, I would like for translate home page... ? Thanks
Support Team posted this 27 November 2017
Unfortunately the static text on slider cannot be translated.
This is a part of the theme design, not the dynamic CMS data.
Please check the following article:
http://answers.themler.io/articles/67127/how-to-add-translatable-static-text
This is the only way.
Hi, Unfortunately the static text on slider cannot be translated. This is a part of the theme design, not the dynamic CMS data. Please check the following article: http://answers.themler.io/articles/67127/how-to-add-translatable-static-text This is the only way. Thank you, Olivia
gael
Is Solution
gael posted this 28 November 2017
Ok it works fine ! Thanks
Gaƫl
Ok it works fine ! Thanks Gaël
