Center Content and Sidebars not possible
lutfi.dwedari
lutfi.dwedari posted this 10 January 2016
I'm trying to set the maximum width of the Content and Sidebars section and to center it horizontally on the page in Themler for Wordpress. The section has a content and a right sidebar. When I set the maximun width of Content & Sidebar, the content is aligned to the left. Setting the margins to auto does not affect the position. Changing Length does nothing.
The videos explaining how to do this use the old UI that has a Position option. But in the new UI position has the CSS meaning so it does not help.
How can I do this? Such a simple thing was trivial in Artisteer, but it takes too much effort in Themler.
I'm trying to set the maximum width of the Content and Sidebars section and to center it horizontally on the page in Themler for Wordpress. The section has a content and a right sidebar. When I set the maximun width of Content & Sidebar, the content is aligned to the left. Setting the margins to auto does not affect the position. Changing Length does nothing. The videos explaining how to do this use the old UI that has a Position option. But in the new UI position has the CSS meaning so it does not help. How can I do this? Such a simple thing was trivial in Artisteer, but it takes too much effort in Themler. Thanks
10 Comments
Support Team posted this 11 January 2016
Please attach your theme so we could review the settings.
Hi, Please attach your theme so we could review the settings. Sincerely, Hella
lutfi.dwedari
lutfi.dwedari posted this 11 January 2016
I'll provide it later but I also tried with a fresh empty theme am I was getting the same issues. I guess you can try that yourshelf.
Lutfi
I'll provide it later but I also tried with a fresh empty theme am I was getting the same issues. I guess you can try that yourshelf. Thanks Lutfi
lutfi.dwedari
Here is a plain theme for WP. It is the latest version (v.161). I've just added a side bar, set the content & sidebar width to 700px and the margins left and right to auto.
Support Team posted this 12 January 2016
Centering the content should be achieved not with the margins but using another options. For the sidebar please go to the Layout >> Right Sidebar >> Add Extension >> layout: Align Content. Set it to center.
For the content column you can set the same extension under the Layout >> Content and Sidebars >> CMS Content. Or if the content is inside the section, you can simply choose the align in the section options.
Hi, Centering the content should be achieved not with the margins but using another options. For the sidebar please go to the Layout >> Right Sidebar >> Add Extension >> layout: Align Content. Set it to center. For the content column you can set the same extension under the Layout >> Content and Sidebars >> CMS Content. Or if the content is inside the section, you can simply choose the align in the section options. Sincerely, Hella
lutfi.dwedari
Is Solution
lutfi.dwedari posted this 12 January 2016
Thanks Hella,
It solved my issue although I had to attach the extension to the Content & Sidebar section instead of separately to Content and to Sidebar.
Lutfi
Thanks Hella, It solved my issue although I had to attach the extension to the Content & Sidebar section instead of separately to Content and to Sidebar. Lutfi
Support Team posted this 13 January 2016
You are welcome. Nice to hear that you have played around this issue and now it is solved.
You are welcome. Nice to hear that you have played around this issue and now it is solved. Sincerely, Hella
dragana
dragana posted this 21 October 2016
I have the same problem. But I can't find Layout - Content and Sidebars - CMS Content.
Support Team posted this 21 October 2016
Now Content and Sidebars tab is located within the Insert tab.
Hi, Now Content and Sidebars tab is located within the Insert tab. Sincerely, Hella
Webstorm
Webstorm posted this 17 March 2017
Where is this option in Themler v.355?
Support Team posted this 20 March 2017
webstorm,
Simply enable sidebars:
Then click on the content area and you will see Content & Sidebars tab where you can enable and configure Sidebars.
webstorm, Simply enable sidebars: !enable-sidebars3.png! Then click on the content area and you will see *Content & Sidebars* tab where you can enable and configure Sidebars. Thank you, Olivia
