WooCommerce Product Categories not displayed
stig
stig posted this 11 January 2016
I have set up WooCommerce to display categories on the Shop Page (WooCommerce > Settings >Products > Display > Shop Page Display > Show categories and sub categories). This setting seems to be ignored by Themler, it displayes products. Using the theme Storefron, the categories are displayed.
16 Comments
Support Team posted this 12 January 2016
Please select Products grid an then enable the Categories.
Thank you!
Hi, Please select Products grid an then enable the Categories. !111.png! Thank you!
Please make sure to enable also this option in Themler:
Hello, Please make sure to enable also this option in Themler: !i191.png! Sincerely, Nettie, BillionDigital Team
info1751
info1751 posted this 02 June 2017
Hi, I have tried this and it is still not showing up.
Support Team posted this 02 June 2017
info1751,
Please make sure that subcategories are set to be displayed in wooCommerce settings as well. If the issue persists, please create a new private topic and provide temporary access to your website for investigation.
**info1751**, Please make sure that subcategories are set to be displayed in wooCommerce settings as well. If the issue persists, please create a new private topic and provide temporary access to your website for investigation. Sincerely, Nettie, BillionDigital Team
swoodley
swoodley posted this 14 September 2017
I have the same problem. Have enabled categories but get categories and products showing?
Support Team posted this 14 September 2017
If the messages above do not help, please create the private topic with the access to the site back end.
Hi, If the messages above do not help, please create the private topic with the access to the site back end. Sincerely, Hella
Yourdigihands
Yourdigihands posted this 07 February 2018
since last update of theme woocommerce sub categories are no longer displayed. in the theme all the settings for displaying sub categories are on..
Support Team posted this 08 February 2018
We have answered in this topic:
https://answers.themler.io/questions/155499/woocommerce-sub-categories-not-displayed
Hello, We have answered in this topic: https://answers.themler.io/questions/155499/woocommerce-sub-categories-not-displayed Sincerely, Nettie, BillionDigital Team
sorin4
sorin4 posted this 08 February 2018
Actually everything was OK before the last woocommerce update, I can confirm that the theme was displaying categories and subcategories and by changing theme everything works as intended.
Te problem is because something was changed in the last version of woocommerce.
PS the link you have posted goes right NOWHERE!
Actually everything was OK before the last woocommerce update, I can confirm that the theme was displaying categories and subcategories and by changing theme everything works as intended. Te problem is because something was changed in the last version of woocommerce. PS the link you have posted goes right NOWHERE!
Support Team posted this 09 February 2018
Could you please create a private topic with the details to access your site back end.
As for the link provided above, you cannot access it now as that topic was moved to private.
Hi, Could you please create a private topic with the details to access your site back end. As for the link provided above, you cannot access it now as that topic was moved to private. Sincerely, Hella
urgull
urgull posted this 19 March 2018
I have same problem , any news about this?
Support Team posted this 19 March 2018
urgull,
Does the issue persist after updating to the latest version, saving and clicking Refresh or F5?
**urgull**, Does the issue persist after updating to the latest version, saving and clicking Refresh or F5? Sincerely, Nettie, BillionDigital Team
777
777 posted this 06 February 2019
I have same problem. Do you have any solution?
Support Team posted this 06 February 2019
Please follow these steps to show subcategories:
  1. In WP admin >> Woocommerce Settings >> Catalog set "Show both" for Shop Page Display and Default Category Display.
  2. Refresh Content in Themler.
  3. Enable showing categories and subcategories on Products template: Products tab >> Categories >> Show Categories, then Category >> Show Category, Subcategories >> Show Subcategories.
  4. The grid for subcategories will appear. Adjust number of columns in Products tab >> Categories >> Subcategories >> Layout.
  5. Add subcategory controls to the grid from Products tab >> Categories >> Subcategories >> Add Control, like Category Name, Category Image etc.
Hello, Please follow these steps to show subcategories: 1. In WP admin >> Woocommerce Settings >> Catalog set "Show both" for Shop Page Display and Default Category Display. 2. Refresh Content in Themler. 3. Enable showing categories and subcategories on Products template: Products tab >> Categories >> Show Categories, then Category >> Show Category, Subcategories >> Show Subcategories. 4. The grid for subcategories will appear. Adjust number of columns in Products tab >> Categories >> Subcategories >> Layout. 5. Add subcategory controls to the grid from Products tab >> Categories >> Subcategories >> Add Control, like Category Name, Category Image etc. Sincerely, Nettie
777
777 posted this 07 February 2019
Hello.
I performed your recommendations, but the grid with subcategories did not appear. Can you help me in any way?
> Hello, > > Please follow these steps to show subcategories: > > 1. In WP admin >> Woocommerce Settings >> Catalog set "Show both" for Shop Page Display and Default Category Display. > 2. Refresh Content in Themler. > 3. Enable showing categories and subcategories on Products template: Products tab >> Categories >> Show Categories, then Category >> Show Category, Subcategories >> Show Subcategories. > 4. The grid for subcategories will appear. Adjust number of columns in Products tab >> Categories >> Subcategories >> Layout. > 5. Add subcategory controls to the grid from Products tab >> Categories >> Subcategories >> Add Control, like Category Name, Category Image etc. > > Sincerely, > Nettie Hello. I performed your recommendations, but the grid with subcategories did not appear. Can you help me in any way?
Support Team posted this 07 February 2019
The grid will be empty until you add some subcategory control like Category Name in there. If there are still difficulties with this, please create a new private topic and provide temporary access to your website for investigation.
Hello, The grid will be empty until you add some subcategory control like Category Name in there. If there are still difficulties with this, please create a new private topic and provide temporary access to your website for investigation. Sincerely, Nettie
