Page background glare as in Artisteer
len
len posted this 12 January 2016
In Artisteer I could add a semi-transparent background glare and also a gradient both of which combine with the background colour.
I can find a gradient setting, but the gradient in Artisteer can be aligned with the header, can't find anything similar in Themler with a split gradient.
There is a background image option, but it does not have the glare options as in Artisteer.
How can I achieve what I had before?
In Artisteer I could add a semi-transparent background glare and also a gradient both of which combine with the background colour. I can find a gradient setting, but the gradient in Artisteer can be aligned with the header, can't find anything similar in Themler with a split gradient. There is a background image option, but it does not have the glare options as in Artisteer. How can I achieve what I had before?
Support Team posted this 13 January 2016
In Themler you can use the Background >> Clipart option, search for the transparent illustrations. More of what you need are under the Arts/Abstract category. Apply some image from the list. If you need to apply the transparent image I suggest to download it first and then add transparency in some graphics editor and then again upload in Themler.
Hi, In Themler you can use the Background >> Clipart option, search for the transparent illustrations. More of what you need are under the Arts/Abstract category. Apply some image from the list. If you need to apply the transparent image I suggest to download it first and then add transparency in some graphics editor and then again upload in Themler. Sincerely, Hella
len
len posted this 13 January 2016
I did look at what you suggest but it is a backward step from Artisteer. Can you please add all the glare and texture graphics from Artisteer into Themler, and the supporting functions to use them, this is a backward step for Artisteer users. The layering of glare, texture and gradient in Artisteer is somewhat missing in Themler.
Themler has much more possibilities and missing this exact option is not a step back. But you can create a topic with a wishlist type so users will vote for this option to pay the attention of the developers.
Or I can change the type of this topic to wishlist in order not to duplicate cases.
Hi, Themler has much more possibilities and missing this exact option is not a step back. But you can create a topic with a wishlist type so users will vote for this option to pay the attention of the developers. Or I can change the type of this topic to wishlist in order not to duplicate cases. Sincerely, Hella
len
Yes please, can you change the topic to wishlist.
LenW
Hella Yes please, can you change the topic to wishlist. Thanks LenW
