Unwanted grey bullets in specifiec views
info1393
info1393 posted this 16 January 2016
The problem is this: when displaying for example a post loop via Essential Grid (from ThemePunch) view or via a slider in the Builder plugin from Themify, the views are accompanied by a grey bullet (see the arrows in the image). The problem doesn't show in other themes, so I think it has something to do with de behaviour of Themler.
The CSS code of the views is:
.bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]) li, .bd-bulletlist li
Can you help me in this?
Hello, The problem is this: when displaying for example a post loop via Essential Grid (from ThemePunch) view or via a slider in the Builder plugin from Themify, the views are accompanied by a grey bullet (see the arrows in the image). The problem doesn't show in other themes, so I think it has something to do with de behaviour of Themler. The CSS code of the views is: .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]) li, .bd-bulletlist li Can you help me in this?
23 Comments
Stagger Lee posted this 16 January 2016
Go to the Post content control (or any you using) - More options and put image none (icon with red line over) in bulletlist options.
info1393
info1393 posted this 17 January 2016
Hello Stagger Lee,
Thanks for the fast reply (and sorry for my late one).
I did what you sugested. I went to Post Content > More Styles > Bullet List > Image and pressed the round icon with the diagonal. But, alas, no result.
Hello Stagger Lee, Thanks for the fast reply (and sorry for my late one). I did what you sugested. I went to Post Content > More Styles > Bullet List > Image and pressed the round icon with the diagonal. But, alas, no result.
Stagger Lee posted this 17 January 2016
I cant tell from image what Control / block it is. If you give URL I can inspect it with Firebug.
Usually it works, I did it many of times.
I cant tell from image what Control / block it is. If you give URL I can inspect it with Firebug. Usually it works, I did it many of times.
info1393
If you want, I can send you the url and the login data. Is there an option to send a private message for that?
Not unfortunately. It would help forum and community big time. And I dont want to leave my email adress in public.
info1393
The site is running on a local server now. I move it to a online server. That takes a few minutes.
info1393
Here it is:
http://test.historischeverenigingmoordrecht.nl/homepage-test/
Here it is: http://test.historischeverenigingmoordrecht.nl/homepage-test/
I dont see bullets. Something is messing with your CSS on homepage. Check in FTP log if all files are transfered OK.
info1393
It schould be working fine now:
It schould be working fine now: http://test.historischeverenigingmoordrecht.nl/homepage-test/
Cant see anything looking like your image.
Disable all caching for a while.
Did you move all Themler CSS inside one custom CSS file ? I dont see any Themler native files.
Cant see anything looking like your image. Disable all caching for a while. Did you move all Themler CSS inside one custom CSS file ? I dont see any Themler native files.
info1393
I can't figure out. I have moved the whole site with the Duplicator Plugin. I use no caching tool and don't work with a special Themler CSS-file.
I've tested the url on 3 different PC's and the site works fine on all of them. The attached image show at what I'm looking at right now.
I can't figure out. I have moved the whole site with the Duplicator Plugin. I use no caching tool and don't work with a special Themler CSS-file. I've tested the url on 3 different PC's and the site works fine on all of them. The attached image show at what I'm looking at right now.!Themler---dots2.jpg! http://test.historischeverenigingmoordrecht.nl/homepage-test/
It should be options in Post content control for this template. Themify_builder is overriding it as it has more narrow priority.
I see you have not removed Bullets in Themler options for this part. Dont know how.
I believe it can be removed in Themler but I am not sure before I see it. If you can leave Admin login, I need only 5-10 minutes to see it. You can after delete this User account.
Later you can download this theme with FTP, overwrite your on localhost and continue to work.
It should be options in Post content control for this template. Themify_builder is overriding it as it has more narrow priority. I see you have not removed Bullets in Themler options for this part. Dont know how. I believe it can be removed in Themler but I am not sure before I see it. If you can leave Admin login, I need only 5-10 minutes to see it. You can after delete this User account. Later you can download this theme with FTP, overwrite your on localhost and continue to work.
But if you want an way I would not reccommend use this in Settings - Additional CSS:
.themify_builder_content li::before,.themify_builder_slider_wrap li::before {
    content: none !important;
But if you want an way I would not reccommend use this in Settings - Additional CSS: .themify_builder_content li::before,.themify_builder_slider_wrap li::before { content: none !important; }
info1393
Username: Historie
Password: Schielandstraat54
Username: Historie Password: Schielandstraat54
It doesnt work.
Wrong Username.
It doesnt work. Wrong Username.
info1393
Sorry. And now?
Sorry. And now?
Now says password for this Username is not correct. Seems as Username now exist and is OK.
info1393
New attempt:
Username: Historie
New attempt: Username: Historie Password: Schielandstraat54
You can delete account now.
It was inside Sections - More options, but you can remove it inside WP Widget area- Content - More options too. There is no Post content on home template.
All you achieve with this Siteorigin, Themify_guilder, or what it is, you can easy achieve with Themler and much more.
It is just making website more slow unnecessary.
You can delete account now. It was inside Sections - More options, but you can remove it inside WP Widget area- Content - More options too. There is no Post content on home template. All you achieve with this Siteorigin, Themify_guilder, or what it is, you can easy achieve with Themler and much more. It is just making website more slow unnecessary.
info1393
Thanks!
About using Themler: I'll give it a try. It's difficult to give up old habits...
Thanks! About using Themler: I'll give it a try. It's difficult to give up old habits...
