Joomla Category List styling?
dg24
dg24 posted this 20 January 2016
Dear Themler Team,
I am currently running into a problem with styling the table of my category list in Joomla. This is what it currently looks like:
My category list table
I have no idea how to change the color of the white border and white alternate row, where do I find these?
Dear Themler Team, I am currently running into a problem with styling the table of my category list in Joomla. This is what it currently looks like: ![My category list table][1] I have no idea how to change the color of the white border and white alternate row, where do I find these? [1]: http://i.imgur.com/Wh410Bf.jpg
Support Team posted this 25 January 2016
to style the table open Styles ribbon >> scroll to Table, select it and switch to Table control options:
Use then to change background color, borders, etc.
Hello, to style the table open Styles ribbon >> scroll to Table, select it and switch to Table control options: !TableSettings.png! Use then to change background color, borders, etc. regards, Aileen
loppini
loppini posted this 21 March 2016
Doesn't work... perhaps it's a bug... I change the style of the table but in category list doesn't change!
Support Team posted this 22 March 2016
Could you please create a separate private ticket and provide an access to your back end so we could review the settings.
Hi, Could you please create a separate private ticket and provide an access to your back end so we could review the settings. Sincerely, Hella
lievenborms
lievenborms posted this 07 October 2017
Dear,
Same problem here.
A normal table responds to the changes in Themler.
Unfortunately, this does not affect the layout of a category list (table of articles).
How can I edit the the layout of a category list?
Best regards,
Dear, Same problem here. A normal table responds to the changes in Themler. Unfortunately, this does not affect the layout of a category list (table of articles). How can I edit the the layout of a category list? Best regards,
Support Team posted this 09 October 2017
This table itself cannot be edited in Themler. The HTML structure of this table as well as its classes is defined by Joomla. This table uses bootstrap table styles. This is defined by joomla too. Themler theme includes bootstrap stylesheet which styles are applied to the table by table classes. Unfortunately there is no option to disable bootstrap styling of this table or change table classes in joomla to change the appearance of this table. Therefore default bootstrap style of this table cannot be removed or changed. The only way is custom css if you're familiar with it.
Hi, This table itself cannot be edited in Themler. The HTML structure of this table as well as its classes is defined by Joomla. This table uses bootstrap table styles. This is defined by joomla too. Themler theme includes bootstrap stylesheet which styles are applied to the table by table classes. Unfortunately there is no option to disable bootstrap styling of this table or change table classes in joomla to change the appearance of this table. Therefore default bootstrap style of this table cannot be removed or changed. The only way is custom css if you're familiar with it. Thank you, Olivia
lievenborms
lievenborms posted this 09 October 2017
Dear,
Thanks for the quick and clear answer.
Now I don't need to look further, I will make adjustments in the relevant css files.
Best regards,
Dear, Thanks for the quick and clear answer. Now I don't need to look further, I will make adjustments in the relevant css files. Best regards,
Support Team posted this 10 October 2017
