Joomla Blog Layout and number of columns
engels
engels posted this 04 February 2016
to determine the number of blogs in content area you have two possibilities.
  1. customized under the Themler >> Blog Template >> choose Posts control >> Layout menu
    In this case you can control number of columns displayed on each device.
  2. You leave this fields empty so Joomlas menu-layout-settings will be taken over
    But in that case you have no control over number of columns displayed on different devices??
    On each device columns are displayed side-by-side.
I want to display different number of columns in Home Template and Page (Blog) Template, but with responsive layout.
How to do that?
Thanks.
Koepi
Hi, to determine the number of blogs in content area you have two possibilities. 1. customized under the Themler >> Blog Template >> choose Posts control >> Layout menu In this case you can control number of columns displayed on each device. 2. You leave this fields empty so Joomlas menu-layout-settings will be taken over But in that case you have no control over number of columns displayed on different devices?? On each device columns are displayed side-by-side. I want to display different number of columns in Home Template and Page (Blog) Template, but with responsive layout. How to do that? Thanks. Koepi
Support Team posted this 05 February 2016
You should customize Posts control before changing its layout:
on each template: Home and Blog.
And then configure the number of columns in Themler.
Hi, You should customize Posts control before changing its layout: !posts-customize.png! on each template: Home and Blog. And then configure the number of columns in Themler. Thank you, Olivia
cachou93
cachou93 posted this 31 December 2017
I have followed your instructions and managed to create 2 different blogs layout. However, how to display them life. I don't see where in Joomla menus, I can apply the chosen layout when I needed.
Please help.
Hello, I have followed your instructions and managed to create 2 different blogs layout. However, how to display them life. I don't see where in Joomla menus, I can apply the chosen layout when I needed. Please help.
Support Team posted this 09 January 2018
Please refer to these instructions on how to use the custom templates:
http://answers.themler.io/articles/10804/how-to-create-and-use-custom-templates
Hi, Please refer to these instructions on how to use the custom templates: http://answers.themler.io/articles/10804/how-to-create-and-use-custom-templates Sincerely, Hella
