Themler v.178 Hot-Fix Update
Support Team posted this 05 February 2016
We've updated Themler from the current Beta version.
The new version is 178.
Here is a list of fixes included in this Themler Hot-Fix update:
General
  • UI improvements.
  • Performance improvements.
  • Fixed issue with jumping page to the top on scroll down.
  • Fixed issue with background image position when gradient is used.
  • Improved error reporting.
  • Fixed other bugs and crashes.
WooCommerce
  • Fixed issue with displaying only one row in products list grid on the latest WooCommerce versions.
Joomla
  • Fixed issue with "Contacts" page.
  • Fixed issue with inability to edit content of the joomla article in Themler if "Show intro text" is enabled under the Article Options.
Drupal
  • Improved validation of the custom templates filenames.
PrestaShop
  • Fixed issue with duplicated menu subitems when multistore is used.
Themler Theme
[post:59335] Thank you, Themler Theme
26 Comments
Stagger Lee posted this 05 February 2016
Latest update gives an way to many "Error occured".
First choice gives error, pages reload, use same choice and goes OK. Something with Appcache ?
It is a bit everywhere, no matter what you click and chose. Theme is Accoons theme.
Latest update gives an way to many "Error occured". First choice gives error, pages reload, use same choice and goes OK. Something with Appcache ? It is a bit everywhere, no matter what you click and chose. Theme is Accoons theme.
Our developers are aware about this crash. They are working on it.
Hi, Our developers are aware about this crash. They are working on it. Thank you, Olivia
olaffitte
olaffitte posted this 05 February 2016
there is always a display problem on the "default template". I'm working on Wordpress, but on Themler interface, I can't get off the escalator, the display remains on the top and middle of the page and can't access to the footer. Is it a bug or a fail of my system?
Hi, there is always a display problem on the "default template". I'm working on Wordpress, but on Themler interface, I can't get off the escalator, the display remains on the top and middle of the page and can't access to the footer. Is it a bug or a fail of my system? Thank you
We're aware about this issue. It happens in Thenler only. It will be fixed in the future Themler updates.
Hi, We're aware about this issue. It happens in Thenler only. It will be fixed in the future Themler updates. Thank you, Olivia
Ok, thanks. Make it a priority, it is really distracting and annoying.
Stagger Lee posted this 08 February 2016
Please leave all aside and take this bug first.
Each time you change template comes "Error occurred.." message. And on many other places.
Please leave all aside and take this bug first. Each time you change template comes "Error occurred.." message. And on many other places.
jimmy.andersson
jimmy.andersson posted this 08 February 2016
Bugg - wordpress:
Trying to use wordpress and playing around with footer.
when klicking rightklick the menu goes down and under the screen and arent avalible for klicking.
Using windows 7 - 64 bit, screen res: 1920-1080p.
Bugg - wordpress: Trying to use wordpress and playing around with footer. when klicking rightklick the menu goes down and under the screen and arent avalible for klicking. Using windows 7 - 64 bit, screen res: 1920-1080p.
jimmy.andersson
Bugg - Forum:
When clicking on "im not a robot".
the picture frame are visible.
but the headline are almost or not visible at all.
So the text with what u are supposed to click on arent showing at all or almost not showing.
Bugg - Forum: When clicking on "im not a robot". the picture frame are visible. but the headline are almost or not visible at all. So the text with what u are supposed to click on arent showing at all or almost not showing. Using windows 7 - 64 bit, screen res: 1920-1080p.
panoulis.th
panoulis.th posted this 09 February 2016
hi
i have update the latest version but i still cannot see the read more option for articles when in blog view
thank you
hi i have update the latest version but i still cannot see the read more option for articles when in blog view thank you
Kommas.nl
Kommas.nl posted this 10 February 2016
First time i'm using Themler instead of Artisteer. Getting Error occurred.." message every 5 minutes.
Please fix this bug fast!
First time i'm using Themler instead of Artisteer. Getting Error occurred.." message every 5 minutes. Please fix this bug fast!
Support Team posted this 11 February 2016
Bugg - Forum:
Could you please provide a screenshot that demonstrates the issue?
We tested CAPTCHA on ouy side but failed to reproduce this issue.
Yesterday we updated Themler BETA. This version should contain a fix for the most common errors.
Please try it and let us know if the constant crashes continue.
Bugg - wordpress:
Does the issue continue with the latest Beta update?
Hi, > Bugg - Forum: When clicking on "im not a robot". the picture frame are visible. but the headline are almost or not visible at all. Could you please provide a screenshot that demonstrates the issue? We tested CAPTCHA on ouy side but failed to reproduce this issue. > Each time you change template comes "Error occurred.." message. And on many other places. Yesterday we updated Themler BETA. This version should contain a fix for the most common errors. Please try it and let us know if the constant crashes continue. > Bugg - wordpress: Trying to use wordpress and playing around with footer. when klicking rightklick the menu goes down and under the screen and arent avalible for klicking Does the issue continue with the latest Beta update? Thank you, Olivia
jimmy.andersson
jimmy.andersson posted this 11 February 2016
Bugg - wordpress:
yes it does.
Have made an clean installation of themler after a new clean windows installation.
> Hi, > > Bugg - wordpress: > Trying to use wordpress and playing around with footer. > when klicking rightklick the menu goes down and under the screen and arent avalible for klicking > > Does the issue continue with the latest Beta update? > > Thank you, > Olivia Hi yes it does. Have made an clean installation of themler after a new clean windows installation.
jimmy.andersson
Bugg - Forum:
No i can't..
Now i don't get the question anymore.
maby it is disabled or maby its becouse i have posted 2 posts.
Maby u can set an marker on my profile so i have to use it every time i want to post anything.
Let me know if u can do anything so i have to use the im not a robot marker.
> Hi, > > > Bugg - Forum: > When clicking on "im not a robot". > the picture frame are visible. > but the headline are almost or not visible at all. > > Could you please provide a screenshot that demonstrates the issue? > We tested CAPTCHA on ouy side but failed to reproduce this issue. > > Thank you, > Olivia Hi No i can't.. Now i don't get the question anymore. maby it is disabled or maby its becouse i have posted 2 posts. Maby u can set an marker on my profile so i have to use it every time i want to post anything. Let me know if u can do anything so i have to use the im not a robot marker.
bagger
bagger posted this 11 February 2016
testing
testing
jimmy.andersson
Bugg - Forum:
Created a new account and it was possible.
here is the screendump
and as soon as i scroll the window.. the captcha disapears.
Best regards.
Jimmy
> > Hi, > > > > > Bugg - Forum: > > When clicking on "im not a robot". > > the picture frame are visible. > > but the headline are almost or not visible at all. > > > > Could you please provide a screenshot that demonstrates the issue? > > We tested CAPTCHA on ouy side but failed to reproduce this issue. > > > > Thank you, > > Olivia > Created a new account and it was possible. here is the screendump and as soon as i scroll the window.. the captcha disapears. Best regards. Jimmy
jimmy.andersson,
Yes, the captcha displays until you verify your email and post a few replies.
This is automatic process. It's not easy to enable it for your profile.
yes it does.
Ok. our developers will check this issue and fix in the future updates.
jimmy.andersson, Yes, the captcha displays until you verify your email and post a few replies. This is automatic process. It's not easy to enable it for your profile. > yes it does. Have made an clean installation of themler after a new clean windows installation. Ok. our developers will check this issue and fix in the future updates. Thank you, Olivia
jimmy.andersson,
Thank you for the screenshot. We'll check this issue.
jimmy.andersson, > here is the screendump Thank you for the screenshot. We'll check this issue. Thank you, Olivia
BillyBob
BillyBob posted this 11 February 2016
I'm receiving all the beta updates so I'm on .187 (not .178 I guess). I got to say, wow! The time it take to save my working template has gone down dramatically. Used to be 7 seconds or more and now it saves in a fraction of that time in most situations for me. Keep up the great development work and thank you!!
One criticism I have is that when you click in a field to type in a value, if the mouse moves just A LITTLE BIT outside of the value box between the time you remove your hand and start typing then your cursor is no longer active inside of that value. It's frustrating to me because when I click inside a value box to type I generally move my mouse too far when I remove my hand from it. Then I have to click inside of the value box again and take care that I don't move the mouse to much before I type.
I'm receiving all the beta updates so I'm on .187 (not .178 I guess). I got to say, wow! The time it take to save my working template has gone down dramatically. Used to be 7 seconds or more and now it saves in a fraction of that time in most situations for me. Keep up the great development work and thank you!! One criticism I have is that when you click in a field to type in a value, if the mouse moves just A LITTLE BIT outside of the value box between the time you remove your hand and start typing then your cursor is no longer active inside of that value. It's frustrating to me because when I click inside a value box to type I generally move my mouse too far when I remove my hand from it. Then I have to click inside of the value box again and take care that I don't move the mouse to much before I type.
Stéphane
Stéphane posted this 11 February 2016
I am using Themler in Joomla! (latest version) and have so many times "An error occurred..." and it reloads not at the position/page I was but on home page and all I have done is lost.
When I try to recover my work, as proposed, I am getting again "An error occurred..." over and over and at the end : lost my work...
I have to save after every click, ie. change of a property to be sure not loosing my latest change.
It is really annoying, can't even work... loosing that much time in modifying one property...
The last hour I am trying to change the post layout, after so many "An error occurred... (more than 20...)" I am writing this message.
What is the real solution ?
What have you done to correct it ?
What have I to do to get it running as in the past, ie. without all that stress ?
I have seen there is a evolution in the beta version, am I concerned ? What is the procedure ?
Themler doesn't propose me to install the beta version... and the links in the help section, when working inside Joomla! and modifying the theme, are pointing a local link, not the real Themler site link.
To get here, I had to open a new TAB, get to the Themler site and go to the forum.
Thanks to give us a real step by step procedure.
WBR,
Stéphane
Hi, I am using Themler in Joomla! (latest version) and have so many times "An error occurred..." and it reloads not at the position/page I was but on home page and all I have done is lost. When I try to recover my work, as proposed, I am getting again "An error occurred..." over and over and at the end : lost my work... I have to save after every click, ie. change of a property to be sure not loosing my latest change. It is really annoying, can't even work... loosing that much time in modifying one property... The last hour I am trying to change the post layout, after so many "An error occurred... (more than 20...)" I am writing this message. What is the real solution ? What have you done to correct it ? What have I to do to get it running as in the past, ie. without all that stress ? I have seen there is a evolution in the beta version, am I concerned ? What is the procedure ? Themler doesn't propose me to install the beta version... and the links in the help section, when working inside Joomla! and modifying the theme, are pointing a local link, not the real Themler site link. To get here, I had to open a new TAB, get to the Themler site and go to the forum. Thanks to give us a real step by step procedure. WBR, Stéphane
Stéphane
Stéphane posted this 12 February 2016
I have investigated if my browser could be the source of my problems.
Goal Modifying a section effect shadow and glow
On Pale moon : I get a lot of : "Sorry, error occurred. Your project will be restored."
On Firefox : I could make the changes without error
On Chrome : I could even not open the template. I get all the time "Sorry, error occurred. Your project will be restored." without seeing anything.
What would be your suggestion about the browser, it's version x86 or x64 I should use on Windows 7 x64 Pro running Joomla! on a virtual Ubuntu server (latest versions) ?
Thanks in advance for you help and advise,
Please forgive me my English as it is not my mother language
WBR,
Stéphane
Hi, I have investigated if my browser could be the source of my problems. Goal Modifying a section effect shadow and glow On Pale moon : I get a lot of : "Sorry, error occurred. Your project will be restored." On Firefox : I could make the changes without error On Chrome : I could even not open the template. I get all the time "Sorry, error occurred. Your project will be restored." without seeing anything. What would be your suggestion about the browser, it's version x86 or x64 I should use on Windows 7 x64 Pro running Joomla! on a virtual Ubuntu server (latest versions) ? Thanks in advance for you help and advise, Please forgive me my English as it is not my mother language WBR, Stéphane
