Content before sidebars on phone responsive
andreseso
andreseso posted this 09 February 2016
I have designed a WordPress template which I am quite pleased. Its URL is http://wp.aquicerca.com
To make this theme perfect, I would like to put content before sidebars in phone responsive view. Any ideas on how I could manage this?
Hello, I have designed a WordPress template which I am quite pleased. Its URL is http://wp.aquicerca.com To make this theme perfect, I would like to put content before sidebars in phone responsive view. Any ideas on how I could manage this? Thanks
Support Team posted this 10 February 2016
You can create right sidebar with the same widgets and enable it only in the responsive view. Also disable the left sidebar in the phone view. The right sidebar will go under the content in responsive view.
Hi, You can create right sidebar with the same widgets and enable it only in the responsive view. Also disable the left sidebar in the phone view. The right sidebar will go under the content in responsive view. Sincerely, Hella
andreseso
andreseso posted this 14 February 2016
Is that the only way? The right sidebar is going to be used as well. We are also using a top sidebar. Could it not be done with CSS?
By the way, with the new Themler user interface I have not been capable of finding the appropriate way to personalize the properties for each of the views. I need to have widgets in different positions depending on which view I use
Is that the only way? The right sidebar is going to be used as well. We are also using a top sidebar. Could it not be done with CSS? By the way, with the new Themler user interface I have not been capable of finding the appropriate way to personalize the properties for each of the views. I need to have widgets in different positions depending on which view I use Thank you
Support Team posted this 15 February 2016
No, that is not possible with the CSS and that's why I have proposed you the solution above.
As for the second issues, provide more details. You can customize the elements the same as before, switch to the desired responsive view and perform the desired changes.
Hi, No, that is not possible with the CSS and that's why I have proposed you the solution above. As for the second issues, provide more details. You can customize the elements the same as before, switch to the desired responsive view and perform the desired changes. Sincerely, Hella
andreseso
andreseso posted this 15 February 2016
Jquery is my friend. How do I find the different ids
How do I set different properties in each of the different views.
Jquery is my friend. How do I find the different ids How do I set different properties in each of the different views. Thank you
Stagger Lee posted this 15 February 2016
Put everything inside columns and it should go this way. I have not tried yet, but guess it must work. One sidebar in one column, content in second colums. Themler has options now to sort order of columns in different devices.
http://answers.themler.com/questions/20593/bootstrap-column-ordering
Put everything inside columns and it should go this way. I have not tried yet, but guess it must work. One sidebar in one column, content in second colums. Themler has options now to sort order of columns in different devices. http://answers.themler.com/questions/20593/bootstrap-column-ordering
