Fancybox on Prestashop
info1938
info1938 posted this 12 February 2016
Hi!
Is there any way to remove the hover effect on product details image?
I want to see large picture on click, not this zoom effect on hover...
Hi! Is there any way to remove the hover effect on product details image? I want to see large picture on click, not this zoom effect on hover...
9 Comments
Support Team posted this 15 February 2016
Unfortunately there is no such possibility as we are using our own code for the CloudZoom in the product image. It can not be switched off now, but we'll add that in our future plans for possible implementations.
Hi, Unfortunately there is no such possibility as we are using our own code for the CloudZoom in the product image. It can not be switched off now, but we'll add that in our future plans for possible implementations. Sincerely, Hella
Maniko
Maniko posted this 04 November 2016
I have the same issue. is there any solution yet with this ugly zoom effect?
thanks and cheers,
mani
Hi, I have the same issue. is there any solution yet with this ugly zoom effect? thanks and cheers, mani
Support Team posted this 07 November 2016
Unfortunately still no news about that.
Unfortunately still no news about that. Sincerely, Hella
Linkebel
Linkebel posted this 07 November 2016
I saw about it quite a few times in the forum
With all those who request it, you could put an available solution, it should not be so complicated
Hi, I saw about it quite a few times in the forum With all those who request it, you could put an available solution, it should not be so complicated
info1135
info1135 posted this 08 November 2016
I have the same problem, if you can implement a solution to choose lightbox or zoom in prestashop would be appreciated by many users. Thanks in advance
Hi, I have the same problem, if you can implement a solution to choose lightbox or zoom in prestashop would be appreciated by many users. Thanks in advance
Support Team posted this 09 November 2016
As a possible solution you can try to remove the cloudzoom.js file from the exported template. But note that you will need to do it every time you save the theme.
Hi, As a possible solution you can try to remove the `cloudzoom.js` file from the exported template. But note that you will need to do it every time you save the theme. Sincerely, Hella
stryjek-www
stryjek-www posted this 01 March 2018
Czy problem zoom jest już rozwiązany. Jak wyłączyć zoom
Support Team posted this 02 March 2018
No, there is no option to disable CloudZoom as it is a feature of our theme.
Hi, No, there is no option to disable CloudZoom as it is a feature of our theme. Sincerely, Hella
LGWeb
LGWeb posted this 17 April 2018
We need this asap. Seems several do.
