Themler just deleted most of my website...
info2163
info2163 posted this 12 February 2016
Themler just deleted most of the sections of my website, didn't allow me to undo anything (pressing the undo button amounted to nothing happening at all), and seems to have saved its progress, as when I restarted Themler -- in the hopes of being able to pick up from when I last saved -- there are now only two sections of my website left.
Fantastic.
Any way of getting my work back?
Themler just deleted most of the sections of my website, didn't allow me to undo anything (pressing the undo button amounted to nothing happening at all), and seems to have saved its progress, as when I restarted Themler -- in the hopes of being able to pick up from when I last saved -- there are now only two sections of my website left. Fantastic. Any way of getting my work back?
6 Comments
info2163
info2163 posted this 13 February 2016
I've had to recreate the missing sections from scratch, as I couldn't find a way to restore my original work.
No idea why Themler randomly decided to delete these sections, but I'm now saving copies of my theme after every major revision, in case this happens again.
I've had to recreate the missing sections from scratch, as I couldn't find a way to restore my original work. No idea why Themler randomly decided to delete these sections, but I'm now saving copies of my theme after every major revision, in case this happens again.
Support Team posted this 17 February 2016
Themler includes the autosave functionality so it is possible to restore the theme if Themler crashes.
But the problem you describe is not known one. In fact it should not happen.
Please contact us if you encounter this problem again.
Hello, Themler includes the autosave functionality so it is possible to restore the theme if Themler crashes. But the problem you describe is not known one. In fact it should not happen. Please contact us if you encounter this problem again. regards, Aileen
online9
online9 posted this 01 November 2017
Themler just deleted the entire joomla article on my static front page after repeated 503 errors involving access to themler.io.
I will now have to reconstruct the whole thing as I can see no way of retrieving it. Any thoughts on how I can a) retrieve the deleted data or b) stop it from happening again.
Themler just deleted the entire joomla article on my static front page after repeated 503 errors involving access to themler.io. I will now have to reconstruct the whole thing as I can see no way of retrieving it. Any thoughts on how I can a) retrieve the deleted data or b) stop it from happening again.
Support Team posted this 02 November 2017
I'm not sure why it happened. We had some server issues before, but they were fixed 15 hours ago. If the issue happened in that time, we are sorry and hope that you have a back up of your site. If the issue is not related to this server issue, then check your server permissions, they should be like this:
http://answers.themler.io/articles/3714/how-to-install-joomla-template
Hi, I'm not sure why it happened. We had some server issues before, but they were fixed 15 hours ago. If the issue happened in that time, we are sorry and hope that you have a back up of your site. If the issue is not related to this server issue, then check your server permissions, they should be like this: http://answers.themler.io/articles/3714/how-to-install-joomla-template Sincerely, Hella
online9
online9 posted this 03 November 2017
The folders have the correct permissions (755). The system works sometimes, but meets the 503 error sometimes. Today, themler decided to update the template (although it was already up to date) and when it finished, I had 4 new sections added to my front page.
I checked the console and got the output attached when the 503 error occurred (also attached)
It seems to be while loading resources from themler.io
The folders have the correct permissions (755). The system works sometimes, but meets the 503 error sometimes. Today, themler decided to update the template (although it was already up to date) and when it finished, I had 4 new sections added to my front page. I checked the console and got the output attached when the 503 error occurred (also attached) It seems to be while loading resources from themler.io
Support Team posted this 08 November 2017
Sorry for the delay. Does the issue continue?
Everything should be ok now.
Hi, Sorry for the delay. Does the issue continue? Everything should be ok now. Thank you, Olivia
