No images in drupal showing
Mitch
Mitch posted this 17 February 2016
Why when i install my drupal theme to the images in slider and everywhere not show?
Support Team posted this 18 February 2016
Could you please try updating Themler to the latst version and let su know if the issue persists. You are working with Themler Desktop, right?
Hello, Could you please try updating Themler to the latst version and let su know if the issue persists. You are working with Themler Desktop, right? Sincerely, Nettie, BillionDigital Team
ohtlik_laeng
ohtlik_laeng posted this 16 May 2018
I got same problem in home page but another nodes are fine. I detected what causes problem and sent it to support but no answer or help, really angry now. Pictures are missing because in front page pictures are in div and set as background image.
Only solution is replace home template to node template in templates.php but this is stupid.
Allready starting to hate themler because i give my mone away and no support at all.
I got same problem in home page but another nodes are fine. I detected what causes problem and sent it to support but no answer or help, really angry now. Pictures are missing because in front page pictures are in div and set as background image. Only solution is replace home template to node template in templates.php but this is stupid. Allready starting to hate themler because i give my mone away and no support at all.
ohtlik_laeng
Only solution for this problem at the moment is manual solution, You need to make changes in templates.php file what is located in templates directory in exported template dir.
My original lines:
<?php?> if (!isset($templates)) $templates = array();
$templates['home'][] = array('id' => '1', 'ui_title'=> 'Home Template', 'd6' => 'front_1', 'd7' => 'front__1', 'name' => 'home', 'caption' => "Home");
I changed 'd7' => 'front__1' to 'd7' => 'node__11'. After this change system uses page template in front/homepage and pictures problem is solved. If somebody knows how to resolve this problem in better way please tel me :)
Only solution for this problem at the moment is manual solution, You need to make changes in templates.php file what is located in templates directory in exported template dir. My original lines: &lt;?php?&gt; if (!isset($templates)) $templates = array(); $templates['home'][] = array('id' => '1', 'ui_title'=> 'Home Template', 'd6' => 'front_1', 'd7' => 'front__1', 'name' => 'home', 'caption' => "Home"); ?> I changed 'd7' => 'front__1' to 'd7' => 'node__11'. After this change system uses page template in front/homepage and pictures problem is solved. If somebody knows how to resolve this problem in better way please tel me :)
