buzico: 1 page design
Seppe
Seppe posted this 18 February 2016
Good evening
I started off with this template because it's a 1 page design.
If you look at te preview, it sure is
But when you import the theme, and do a preview, it's just a normal cms
How can we use this "1 page design"?
greetings
Good evening I started off with this template because it's a 1 page design. If you look at te preview, it sure is But when you import the theme, and do a preview, it's just a normal cms How can we use this "1 page design"? greetings
Support Team posted this 19 February 2016
You need to configure the menu correctly within Joomla:
http://answers.themler.com/articles/5582/one-page-design-in-joomla
Hi, You need to configure the menu correctly within Joomla: http://answers.themler.com/articles/5582/one-page-design-in-joomla Sincerely, Hella
Seppe
Seppe posted this 20 February 2016
Good afternoon Hella
Yes, I know that topic, but it's for me absolutely not clear
1. Open the theme at the Home page.
Where? In Themler or Internet Explorer?
2. Add several Row with Columns controls using Insert >> Row with Columns. The number of Row with Columns controls should match the number of pages you would like to create. Configure Rows to have one column.
3. At this step, add special controls to output Joomla content. For example, let's add the Joomla Position control to output one of the Joomla modules. Locate them in every Row.
4. Add the Horizontal Menu control from Insert >> Navigation >> Horizontal Menu if it does not exist.
That is already done in the theme I suppose?
5. Click 'Apply Theme to CMS' and open the theme in the Joomla Administration back-end.
I have no clue where to click.
Good afternoon Hella Yes, I know that topic, but it's for me absolutely not clear **1. Open the theme at the Home page.** Where? In Themler or Internet Explorer? **2. Add several Row with Columns controls using Insert >> Row with Columns. The number of Row with Columns controls should match the number of pages you would like to create. Configure Rows to have one column. 3. At this step, add special controls to output Joomla content. For example, let's add the Joomla Position control to output one of the Joomla modules. Locate them in every Row. 4. Add the Horizontal Menu control from Insert >> Navigation >> Horizontal Menu if it does not exist.** That is already done in the theme I suppose? **5. Click 'Apply Theme to CMS' and open the theme in the Joomla Administration back-end.** I have no clue where to click.
Support Team posted this 21 February 2016
  1. This should be done in Themler.
  2. You can use sections instead of rows now.
  3. If working on the live site, simply press Save button to save the changes to your site.
Hi, 1. This should be done in Themler. 2. You can use sections instead of rows now. 5. If working on the live site, simply press Save button to save the changes to your site. Sincerely, Hella
