How to install and customise a blank template in joomla
jackymoore10
jackymoore10 posted this 19 February 2016
uploading blank template to joomla, when clicking on edit template I just got a black white box and was not able to edit with themler like in the box, Help?
Denis L.
Denis L. posted this 19 February 2016
From what I see on your screenshot, you seem to be using an old version of Joomla like 2.5... maybe upgrade to the latest Joomla version? V.3.4.8
Maybe that could be more compatible with Themler?
From what I see on your screenshot, you seem to be using an old version of Joomla like 2.5... maybe upgrade to the latest Joomla version? V.3.4.8 Maybe that could be more compatible with Themler?
jackymoore10
When I go to my administration in joomla it says You already have the latest Joomla! version, 2.5.22. but I can see when I google that there is indeed the 3.4.8 version you are talking about how do I go about installing this?
Denis L.
You have to do a jump upgrade form Joomla 2.5.22 to Joomla 3.3.x and from there, you'll be able to update from 3.3 to 3.4.8.
All is explained here on the official Joomla docs https://docs.joomla.org/Joomla_2.5_to_3.x_Step_by_Step_Migration ... read everything carefully and also, be sure to do a full backup of your website and database before proceeding. ;-)
Also remember that you will have to update all your third party extensions so they can be compatible with your new Joomla 3.4.x
You have to do a jump upgrade form Joomla 2.5.22 to Joomla 3.3.x and from there, you'll be able to update from 3.3 to 3.4.8. All is explained here on the official Joomla docs https://docs.joomla.org/Joomla_2.5_to_3.x_Step_by_Step_Migration ... read everything carefully and also, be sure to do a full backup of your website and database before proceeding. ;-) Also remember that you will have to update all your third party extensions so they can be compatible with your new Joomla 3.4.x
jordi.bistuer
jordi.bistuer posted this 3 weeks ago
I can not upload the blank_themler_joomla_theme.zip because maximum size for uploading in joomla is 3 Mb but the blank_themler_joomla_theme.zip is 6 Mb.
What can I do?
Joomla versión 3.8.8
Wamp 2.5
I can not upload the **blank_themler_joomla_theme.zip** because maximum size for uploading in joomla is 3 Mb but the **blank_themler_joomla_theme.zip** is 6 Mb. What can I do? Joomla versión 3.8.8 Wamp 2.5
Please follow the way to install an unpacked template via FTP (the second part of the article):
http://answers.themler.io/articles/3714/how-to-install-joomla-template
Or to increase the file upload limit size, please search for the line like “upload_max_filesize = 2M” in php.ini and change the value to your desired value.
Hello, Please follow the way to install an unpacked template via FTP (the second part of the article): http://answers.themler.io/articles/3714/how-to-install-joomla-template Or to increase the file upload limit size, please search for the line like `“upload_max_filesize = 2M”` in `php.ini` and change the value to your desired value. Sincerely, Nettie
