Copy a pre-defined column
Seppe
Seppe posted this 20 February 2016
How can I copy an aleady predefined column?
I have a layout with 2 columns, and I want to make a 3th, as an exact copy of the first column.
I want to have this done, without struggeling to get them exactly the same configurated, because it was already done in the 1st column
greetings
How can I copy an aleady predefined column? I have a layout with 2 columns, and I want to make a 3th, as an exact copy of the first column. I want to have this done, without struggeling to get them exactly the same configurated, because it was already done in the 1st column greetings
6 Comments
Support Team posted this 22 February 2016
Hi Seppe,
Please try using Copy Style option for the first column on right click and then Paste Style for the third column:
Hi Seppe, Please try using Copy Style option for the first column on right click and then Paste Style for the third column: !i246.png! Sincerely, Nettie, BillionDigital Team
Seppe
Seppe posted this 22 February 2016
Goof afternoon
This doesn't seem to work.
What I ment was like in the attached file.
The first column has a full layout: text, spacer, icons, ....
The second column is empty
Now I want an exact copy of the first column in the second column
greetings
Seppe
Goof afternoon This doesn't seem to work. What I ment was like in the attached file. The first column has a full layout: text, spacer, icons, .... The second column is empty Now I want an exact copy of the first column in the second column greetings Seppe
Hello Seppe,
Currently it is possible, to copy and paste separate controls from one column to another one. Since a column are not a separate control but a part of the single Columns control, it is not possible to copy a separate Column, however I have added this option to our Wishlist. As a possible solution, you may put any container inside the column, put controls there and then copy the container to the second column.
Hello Seppe, Currently it is possible, to copy and paste separate controls from one column to another one. Since a column are not a separate control but a part of the single Columns control, it is not possible to copy a separate Column, however I have added this option to our Wishlist. As a possible solution, you may put any container inside the column, put controls there and then copy the container to the second column. Sincerely, Nettie, BillionDigital Team
lesergei
lesergei posted this 08 March 2016
It would be nice to make a copy of a column, you can make a duplicate of a slide, which simplifies making and manipulation, why not have a duplicate function for columns.
Hello, It would be nice to make a copy of a column, you can make a duplicate of a slide, which simplifies making and manipulation, why not have a duplicate function for columns. Thank you
hdesai
hdesai posted this 23 April 2016
I think this should be more easy to have copy and paste control over the whole section | div or any damn thing that we want exactly same with look and content.
Please update with this !!!!
http://s31.postimg.org/kc0eg9ojv/themler.png
Here is the link and I am attaching the file also.
In this image I have 3 columns which are almost having same look and styling. Now I had to create all this columns from scratch. But it would be easier and lesser time consuming if I would be able to copy and paste first column | div to last one.
Parth
I think this should be more easy to have copy and paste control over the whole section | div or any damn thing that we want exactly same with look and content. Please update with this !!!! http://s31.postimg.org/kc0eg9ojv/themler.png Here is the link and I am attaching the file also. In this image I have 3 columns which are almost having same look and styling. Now I had to create all this columns from scratch. But it would be easier and lesser time consuming if I would be able to copy and paste first column | div to last one. Regards, Parth
Support Team posted this 26 April 2016
Hello Parth,
The suggestion is in our Wishlist. Please vote for this feature, this will help us to see how relevant it is.
Sincerel,y
Hello Parth, The suggestion is in our Wishlist. Please **vote** for this feature, this will help us to see how relevant it is. Sincerel,y Nettie, BillionDigital Team
