Empty Column Display like Artisteer
DaveOzric
DaveOzric posted this 22 February 2016
Hello, I would like to know if empty columns containing Joomla module positions can be set to not take up that space if some are empty.
Like Artisteer or other bootstrap templates I have seen when there is only 3 modules they are spread out evenly across the space of the container.
Not sure if this makes sense. In my footer I have 4 columns with a Joomla module position in each. If I would like the 3 columns to be evenly distributed when there less than 4.
Hello, I would like to know if empty columns containing Joomla module positions can be set to not take up that space if some are empty. Like Artisteer or other bootstrap templates I have seen when there is only 3 modules they are spread out evenly across the space of the container. Not sure if this makes sense. In my footer I have 4 columns with a Joomla module position in each. If I would like the 3 columns to be evenly distributed when there less than 4. Thank you !2016-02-22-092540.jpg! !2016-02-22-092508.jpg!
Stagger Lee posted this 22 February 2016
There are some classes but not in Themler as I am aware of.
Best to try with Layout container and display: inline-block for widget areas. No fast width. But then your widget content will influence much, they need not to break to new line.
There are some classes but not in Themler as I am aware of. Best to try with Layout container and display: inline-block for widget areas. No fast width. But then your widget content will influence much, they need not to break to new line.
john106
john106 posted this 23 February 2016
Why not just create another row with 3 columns above or below the 4 column row. Then when using 3 modules, simply shift the modules to the 3 column row, and vice-verse. If nothing is in a particular row, it doesn't show anyway.
DaveOzric
DaveOzric posted this 23 February 2016
I was mostly curious how Artisteer does this. Themler and bootstrap may work differently.
Thanks for the suggestions. Mostly footers are the same across whole site. but I guess it would be more about other areas possibly. Still learning.
I was mostly curious how Artisteer does this. Themler and bootstrap may work differently. Thanks for the suggestions. Mostly footers are the same across whole site. but I guess it would be more about other areas possibly. Still learning.
