Swittching between CMS systems
Jwhissell
Jwhissell posted this 25 February 2016
I designed a template in Themler under the CMS Joomla. However, Now I need to export that same CMS to a wordpress, how?
When I export it from Joomla section and then import it into the WordPress section it fails saying it cannot locate the style sheet.
I designed a template in Themler under the CMS Joomla. However, Now I need to export that same CMS to a wordpress, how? When I export it from Joomla section and then import it into the WordPress section it fails saying it cannot locate the style sheet.
Support Team posted this 25 February 2016
Unfortunately now you can not switch between the CMSs. You will need to create the new design for the different CMS.
Hi, Unfortunately now you can not switch between the CMSs. You will need to create the new design for the different CMS. Sincerely, Hella
Jwhissell
Please add that to the top of a wish list item!!! I need that so terribly badly.
Jordan Whissell.
Please add that to the top of a wish list item!!! I need that so terribly badly. Thank you, Jordan Whissell.
OK, added this feature to our wish list for possible future implementations.
OK, added this feature to our wish list for possible future implementations. Sincerely, Hella
Lex
Lex posted this 15 November 2018
Update ???
Please import this "Artisteer" Feature !
81 Votes and here 2 Votes
http://answers.themler.io/questions/25645/export-any-theme-to-multiple-cms-platforms-just-like-artisteer-does
Update ??? Please import this "Artisteer" Feature ! Thanks 81 Votes and here 2 Votes http://answers.themler.io/questions/25645/export-any-theme-to-multiple-cms-platforms-just-like-artisteer-does
Support Team posted this 16 November 2018
Sorry but at the moment this option is not in our nearest plans. In fact, it is really a question to implement this possibility since unlike Artisteer, Themler themes have different structure, and here you can work with real CMS content and CMS-specific controls like Widget area etc. that can also be designed in Themler.
However please consider using sections for the purpose of transferring some theme parts. Sections can have different containers and controls inside them, and you can export and import ready sections in themes for different CMS's.
Hello, Sorry but at the moment this option is not in our nearest plans. In fact, it is really a question to implement this possibility since unlike Artisteer, Themler themes have different structure, and here you can work with real CMS content and CMS-specific controls like Widget area etc. that can also be designed in Themler. However please consider using sections for the purpose of transferring some theme parts. Sections can have different containers and controls inside them, and you can export and import ready sections in themes for different CMS's. Sincerely, Nettie
