Themler - mobile layout - menu display
TSMM
TSMM posted this 17 January 2015
How do I edit the nav menu bar on mobile layout. It shows the menu icon, but when you click on it the menu goes crazy, unusable. First attachment is showing how it looks now.
I want to have it so when someone clicks on the menu icon the main menu links drop down for the user to select from. Attached is a screen shot of a different website where the menu icon works on mobile.
How do I edit the nav menu bar on mobile layout. It shows the menu icon, but when you click on it the menu goes crazy, unusable. First attachment is showing how it looks now. I want to have it so when someone clicks on the menu icon the main menu links drop down for the user to select from. Attached is a screen shot of a different website where the menu icon works on mobile.
10 Comments
Support Team posted this 17 January 2015
Horizontal Menu works fine in responsive modes.
Just click Live Preview icon.
Resize your browser to a smaller size and click the the menu icon.
If you want to do the same in Themler.
Please right-click and click Open Link.
**Horizontal Menu** works fine in responsive modes. Just click **Live Preview** icon. Resize your browser to a smaller size and click the the menu icon. !LivePreview.png! !browser.png! If you want to do the same in Themler. Please right-click and click **Open Link**. !openlink.png!
TSMM
I can see the responsive menu icon, but I can see the menu items under it when I click on it. Attached is a screenshot of the view from a mobile, the menu links are pushed way out to the right off the screen and with large gaps in between.
When I try to edit the mobile menu, it makes the changes to all layouts not just mobile.
I can see the responsive menu icon, but I can see the menu items under it when I click on it. Attached is a screenshot of the view from a mobile, the menu links are pushed way out to the right off the screen and with large gaps in between. When I try to edit the mobile menu, it makes the changes to all layouts not just mobile.
Tracy,
To change only menu responsive properties, please switch to a responsive mode first.
See image below.
It is difficult to say why your menu has "large gaps",
maybe you changed Menu Item Margin or Padding.
If you cannot fix this, please create a new separate private topic
and provide us admin access to your CMS (URL, login, pwd) and we check this.
Oleg
Tracy, To change only menu responsive properties, please switch to a responsive mode first. See image below. !responsive.png! It is difficult to say why your menu has "large gaps", maybe you changed Menu Item Margin or Padding. If you cannot fix this, please create a new separate private topic and provide us admin access to your CMS (URL, login, pwd) and we check this. Thanks, Oleg
stryjek-www
stryjek-www posted this 16 December 2015
Mam pytanie. Jak włączyć responsywne menu na tabletach. Teraz mam tylko na smartfonach. Jak włączyć aby włączało się już od tabletów
Support Team posted this 17 December 2015
Please have a look at the attached screenshot. It demonstrates how you can enable responsive menu starting from the Tablet mode:
Ivan
Hi, Please have a look at the attached screenshot. It demonstrates how you can enable responsive menu starting from the Tablet mode: !case6400.png! Please let us know if you have any further questions. Thanks, Ivan
isabella.quintana
isabella.quintana posted this 01 March 2016
Hello I'm having this problem (attached) when the mobile menu displays. How can I adjust it not to be behind the content. Thanks!
Support Team posted this 02 March 2016
Please change the z-index parameter in the Property Window for the Menu.
Thank you!
Please change the z-index parameter in the Property Window for the Menu. Thank you!
stryjek-www
stryjek-www posted this 14 April 2016
Witam Mam problem z menu mobilnym. Na stronie www.max-kasa.pl w wersji mobilnej menu rozwija się prawidłowo lecz nie ukrywa się po kliknięciu w napis menu. Jak ustawić aby menu się chowało po naciśnięciu napisu menu Strona typu onepage
Support Team posted this 19 April 2016
Unfortunately menu closes on page reload.
In your case it cannot be closed.
Hi, Unfortunately menu closes on page reload. In your case it cannot be closed. Thank you, Olivia
darwin.cbf
darwin.cbf posted this 04 February 2019
Thank you!
change the parameter and the problem persists
> Please change the z-index parameter in the Property Window for the Menu. > > Thank you! change the parameter and the problem persists
