Add section to HTML Modules
DaveOzric
DaveOzric posted this 28 February 2016
Is there a way to add a section to a Joomla module like you can to an Article?
Is there a way to add a section to a Joomla module like you can to an Article? Thanks
23 Comments
Support Team posted this 29 February 2016
There is no such possibility in Themler.
Hi, There is no such possibility in Themler. Sincerely, Hella
DaveOzric
DaveOzric posted this 29 February 2016
Ok thanks, I'll just keep doing it the way I am now then.
Support Team posted this 02 March 2016
You are welcome.
Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
DaveOzric
DaveOzric posted this 14 December 2016
Hello, I am seeing more need for this. Anyway you can add this to your roadmap of features? A custom html module in Joomla with sections from Themler would be really handy.
Hello, I am seeing more need for this. Anyway you can add this to your roadmap of features? A custom html module in Joomla with sections from Themler would be really handy. Thanks
Support Team posted this 15 December 2016
I've added your request to our wish list.
In the meantime you can try copying Section shortcode to the HTML module manually. In the Section is not working please check this article:
http://answers.themler.com/articles/65513/themler-themes-issues-joomla-virtuemart#shortcodes
Unfortunately the Section added to the module will not be editable in Themler.
Hi, I've added your request to our wish list. In the meantime you can try copying Section shortcode to the HTML module manually. In the Section is not working please check this article: http://answers.themler.com/articles/65513/themler-themes-issues-joomla-virtuemart#shortcodes Unfortunately the Section added to the module will not be editable in Themler. Thank you, Olivia
DaveOzric
DaveOzric posted this 15 December 2016
Hello, can you explain how to copy shortcode of a section?
Hello, can you explain how to copy shortcode of a section? Thanks
Hello Dave,
if there's exported section (Export as ZIP option of Section control) you may copy the HTML code from the section.html file and paste all this code to Joomla Custom HTML module type.
Hello Dave, if there's exported section (Export as ZIP option of Section control) you may copy the HTML code from the `section.html` file and paste all this code to Joomla Custom HTML module type. Regards, Aileen
DaveOzric
DaveOzric posted this 19 December 2016
Hello, good to know, I'll try that.
Support Team posted this 20 December 2016
Please let us know if you need our further help.
Please let us know if you need our further help. Sincerely, Hella
DaveOzric
DaveOzric posted this 26 August 2017
Hello, I am still confused and have not tried this yet. Where do you build the section on a Joomla template? It has to be on the site somewhere for the css to be applied, correct? I can't build the section in say the desktop version and export it then copy the code can I? Where would the styles be?
So do I need to create a new template in Themler for Joomla and house all my custom sections there? Sure would be nice to have a Themler Module added to Joomla that sections can be built in.
Hello, I am still confused and have not tried this yet. Where do you build the section on a Joomla template? It has to be on the site somewhere for the css to be applied, correct? I can't build the section in say the desktop version and export it then copy the code can I? Where would the styles be? So do I need to create a new template in Themler for Joomla and house all my custom sections there? Sure would be nice to have a Themler Module added to Joomla that sections can be built in. Thank you
DaveOzric
DaveOzric posted this 28 August 2017
Themler team can you elaborate on this?
Please add a Joomla module that can create sections to really make the whole thing work optimally.
Themler team can you elaborate on this? Please add a Joomla module that can create sections to really make the whole thing work optimally.
Support Team posted this 29 August 2017
Sorry for the delay.
The Section itself cannot be added into the Joomla HTML module. But you can take the the existing shortcode and paste it into the joomla HTML module.
You can create special article where you will add Section in Themler on your production server or on Themler Desktop. There is no really difference because Section specific css is a part of the Section. But the same Section may look differently because it uses theme styles also. For better visualization we suggest that you use the same theme if you're going to add Sections on Themler Desktop. The easiest way is to add sections to some articles on the same server. In this case you will be able to quickly edit this Section in Themler and update the shortcode in the module if needed.
Hi, Sorry for the delay. The Section itself cannot be added into the Joomla HTML module. But you can take the the existing shortcode and paste it into the joomla HTML module. You can create special article where you will add Section in Themler on your production server or on Themler Desktop. There is no really difference because Section specific css is a part of the Section. But the same Section may look differently because it uses theme styles also. For better visualization we suggest that you use the same theme if you're going to add Sections on Themler Desktop. The easiest way is to add sections to some articles on the same server. In this case you will be able to quickly edit this Section in Themler and update the shortcode in the module if needed. Please let us know if you have any further questions. Thank you, Olivia
DaveOzric
DaveOzric posted this 29 August 2017
OK, this makes more sense now. I did not know about the css being in the section.
Hopefully a feature for a Themler based module in Joomla will come someday to complete the program.
OK, this makes more sense now. I did not know about the css being in the section. Hopefully a feature for a Themler based module in Joomla will come someday to complete the program. Thank you
Support Team posted this 30 August 2017
You are welcome. We'll consider your suggestion for the future implementations.
You are welcome. We'll consider your suggestion for the future implementations. Sincerely, Hella
DaveOzric
DaveOzric posted this 31 August 2017
Hello, do you think the best option is to create a specific new template called "module-sections" and house all the sections there? I would rather not do it with articles to avoid users from seeing them in the admin area.
This method would cause no issues correct?
Hello, do you think the best option is to create a specific new template called "module-sections" and house all the sections there? I would rather not do it with articles to avoid users from seeing them in the admin area. This method would cause no issues correct? Thank you
DaveOzric
Hello, I am testing this and now see a big issue. Images do not seem to be added to the section. Is this because I am using a template to create them and not articles? Either way I am exporting the section so how do you include images?
This is why the module idea is going to be so great. All done in the CMS.
Hello, I am testing this and now see a big issue. Images do not seem to be added to the section. Is this because I am using a template to create them and not articles? Either way I am exporting the section so how do you include images? This is why the module idea is going to be so great. All done in the CMS.
Support Team posted this 01 September 2017
The Section shortcode includes all custom section css including css for background images. But it does not include images physically (image files). You need to upload them manually if you're doing the Section outside of the current theme.
And please note that shortcode contains a path to the background image, for example:
[section title="Row with Background Image" id="section4" wide=true css_md="padding-right:2em;" css_sm="padding-bottom:4em;padding-top:4em;" typography_sm="Text {line-height: 24px;font-size: 16px;}H2 {line-height: 36px;font-size: 30px;}H1 {line-height: 86.4px;font-size: 72px;}" css_xs="padding-left:1em;padding-right:1em;padding-bottom:1em;" typography_xs="H1 {line-height: 68.57142859px;font-size: 48px;}" css="background-color:#ffffff;position:relative;background-image:url(http://wordpress.4.i68802.cms1-live.billiondigital.com/wp-content/uploads/2017/09/885ae6b7c5b3254d696ecb8e446b6813_light300431_1920.jpg);background-repeat:repeat;background-attachment:scroll;background-position:center top;background-size:cover;height:100vh;padding-right:5em;padding-left:5em;" typography="Text {line-height: 28.5px;color: #ffffff;font-size: 19px;font-weight: 400;letter-spacing: 1px;text-align: right;}H2 {line-height: 41.4px;font-size: 36px;font-weight: 300;}H1 {line-height: 90px;text-transform: uppercase;font-size: 90px;color: #ffffff;font-weight: 300;letter-spacing: -2px;}"]
If you're working with the current theme to create Sections for modules the theme will export and save images instead of you.
So, the best way is to work on the same server with the same theme.
Hi, The Section shortcode includes all custom section css including css for background images. But it does not include images physically (image files). You need to upload them manually if you're doing the Section outside of the current theme. And please note that shortcode contains a path to the background image, for example: > [section title="Row with Background Image" id="section4" wide=true css_md="padding-right:2em;" css_sm="padding-bottom:4em;padding-top:4em;" typography_sm="Text {line-height: 24px;font-size: 16px;}H2 {line-height: 36px;font-size: 30px;}H1 {line-height: 86.4px;font-size: 72px;}" css_xs="padding-left:1em;padding-right:1em;padding-bottom:1em;" typography_xs="H1 {line-height: 68.57142859px;font-size: 48px;}" css="background-color:#ffffff;position:relative;<b>background-image:url(http://wordpress.4.i68802.cms1-live.billiondigital.com/wp-content/uploads/2017/09/885ae6b7c5b3254d696ecb8e446b6813_light300431_1920.jpg);</b>background-repeat:repeat;background-attachment:scroll;background-position:center top;background-size:cover;height:100vh;padding-right:5em;padding-left:5em;" typography="Text {line-height: 28.5px;color: #ffffff;font-size: 19px;font-weight: 400;letter-spacing: 1px;text-align: right;}H2 {line-height: 41.4px;font-size: 36px;font-weight: 300;}H1 {line-height: 90px;text-transform: uppercase;font-size: 90px;color: #ffffff;font-weight: 300;letter-spacing: -2px;}"] If you're working with the current theme to create Sections for modules the theme will export and save images instead of you. So, the best way is to work on the same server with the same theme. Thank you, Olivia
DaveOzric
DaveOzric posted this 01 September 2017
It appears all images go in the images/editor/content folder so could they just be uploaded manually in there after the section zip is extracted?
Support Team posted this 07 September 2017
You just need to match the path to the image and the location of the image.
That's why I suggested adding sections to the article on the same server. In this case it will be enough to copy the shortcode. In case of crating section in other place you will need to manually upload images.
Hi, You just need to match the path to the image and the location of the image. That's why I suggested adding sections to the article on the same server. In this case it will be enough to copy the shortcode. In case of crating section in other place you will need to manually upload images. Thank you, Olivia
DaveOzric
DaveOzric posted this 07 September 2017
That makes sense. I'll test some options and see how it goes. Sure is a lot of work to build, export, etc.
I really hope you add a module someday soon though because some pages are not articles and there is no way to do this easily.
I can't believe more people don't ask for this?
That makes sense. I'll test some options and see how it goes. Sure is a lot of work to build, export, etc. I really hope you add a module someday soon though because some pages are not articles and there is no way to do this easily. I can't believe more people don't ask for this? Thank you
