HTML5 404 Page
DaveOzric
DaveOzric posted this 01 March 2016
Hello, is it possible to have a 404 page on the HTML5 website?
Hello, is it possible to have a 404 page on the HTML5 website? Thanks
9 Comments
Support Team posted this 02 March 2016
You can add it in the page list. Disable its display in the menus. Then redirect your 404 to this page.
Thank you!
You can add it in the page list. Disable its display in the menus. Then redirect your 404 to this page. !111.png! Thank you!
DaveOzric
DaveOzric posted this 02 March 2016
I was hoping it could be built in like the templates for the CMS sites. What do you redirect it with?
Support Team posted this 03 March 2016
Hello Dave,
in HTML sites the redirect mechanism to 404 page is not implemented (like in CMS themes)
Custom 404 page could be created manually on web server end.
Refer to one of articles
http://www.htmlgoodies.com/beyond/reference/article.php/3472591/How-Do-I-Create-a-Custom-404-Error-Page.htm
https://www.digitalocean.com/community/tutorials/how-to-create-a-custom-404-page-in-apache
Hello Dave, in HTML sites the redirect mechanism to 404 page is not implemented (like in CMS themes) Custom 404 page could be created manually on web server end. Refer to one of articles http://www.htmlgoodies.com/beyond/reference/article.php/3472591/How-Do-I-Create-a-Custom-404-Error-Page.htm https://www.digitalocean.com/community/tutorials/how-to-create-a-custom-404-page-in-apache Regards, Aileen
DaveOzric
DaveOzric posted this 03 March 2016
OK, thanks for your help on this!
Support Team posted this 04 March 2016
You are welcome.
You are welcome. Sincerely, Hella
DaveOzric
Is Solution
DaveOzric posted this 05 March 2016
So to follow up on this. I was concerned this would not be a real 404 status but doing it this way will work.
On Apache cPanel you can create a 404.shtml file in your cPanel Error Pages options for each domain.
This will then put a 404.shtml file in your root of the domain. Then you can edit that some basic text and a link to the homepage.
Then in your .htaccess file simple add the one line and save that.
ErrorDocument 404 /404.shtml
You will have to create a .htaccess file if you don't have one. Addon domains usually don't.
I use a robots.txt or head tag with no index to avoid search engines indexing the page.
Pretty easy.
So to follow up on this. I was concerned this would not be a real 404 status but doing it this way will work. On Apache cPanel you can create a 404.shtml file in your cPanel Error Pages options for each domain. This will then put a 404.shtml file in your root of the domain. Then you can edit that some basic text and a link to the homepage. Then in your .htaccess file simple add the one line and save that. ErrorDocument 404 /404.shtml You will have to create a .htaccess file if you don't have one. Addon domains usually don't. I use a robots.txt or head tag with no index to avoid search engines indexing the page. Pretty easy.
DaveOzric
DaveOzric posted this 06 May 2017
Is it possible to add this someday? Would be nice to have a nice fancy one like the CMS sites can.
Is it possible to add this someday? Would be nice to have a nice fancy one like the CMS sites can. Thanks
Themler exports plain html and css. The 404 redirection is server side task. You can create page named 404 and configure redirect to this page. This task is not for static html website itself.
Hi, Themler exports plain html and css. The 404 redirection is server side task. You can create page named 404 and configure redirect to this page. This task is not for static html website itself. Thank you, Olivia
DaveOzric
DaveOzric posted this 08 May 2017
Hello, that's fine. Adding a cPanel 404.shtml page is more than fine. Now that you explained it I understand.
Hello, that's fine. Adding a cPanel 404.shtml page is more than fine. Now that you explained it I understand. Thanks
