Frontsite IE and Chrome not the same (Order from article with two column)
matrix630307
matrix630307 posted this 02 March 2016
I work with joomla and i have a site: www.schule-schwaderloch.ch/relaunch16
On frontsite, i have two columns (in themler i have not defined - the two columns are in the joomla menu defined).
on chrome, the frontsite work fine (see Aufnahme4.jpg). On IE 11 i have a empty place for an article (see Aufnahme3.jpg).
On first call the site, i have not this problem with IE 11. but when you click then on menu "home", the place will be white.
what's the problem here?
Hi I work with joomla and i have a site: www.schule-schwaderloch.ch/relaunch16 On frontsite, i have two columns (in themler i have not defined - the two columns are in the joomla menu defined). on chrome, the frontsite work fine (see Aufnahme4.jpg). On IE 11 i have a empty place for an article (see Aufnahme3.jpg). On first call the site, i have not this problem with IE 11. but when you click then on menu "home", the place will be white. what's the problem here?
Support Team posted this 02 March 2016
Please note that some features are not fully supported in IE11 due to limitations of IE. We are working on fixing this issues.
Thank you!
Please note that some features are not fully supported in IE11 due to limitations of IE. We are working on fixing this issues. Thank you!
matrix630307
hi
i mean a right show from columns is not a features. i be happy, when you are working on fixing this issue.
thank you
hi i mean a right show from columns is not a features. i be happy, when you are working on fixing this issue. thank you
Support Team posted this 03 March 2016
Our developers aware about this issue. They will try to fix it in the future Themler updates.
Hi, Our developers aware about this issue. They will try to fix it in the future Themler updates. Thank you, Olivia
matrix630307
matrix630307 posted this 03 March 2016
yes - that's great!
thank you Olivia
yes - that's great! thank you Olivia
Support Team posted this 04 March 2016
You are welcome, I hope that the issue will be fixed soon.
You are welcome, I hope that the issue will be fixed soon. Sincerely, Hella
