Creating a menu module that appears on all pages of a joomla template?
nthusiastic2learn
nthusiastic2learn posted this 08 March 2016
First of all I am a themler noob and have been using your software only a couple of days. I have a few questions about the software
1)I have run into a problem with using your joomla template feature. I have created a joomla horizontal menu and have placed it on the home page of the template. I hasve exported the template, installed it on joomla and created a new menu item called test to see if the menu appears. To my surprise I could not see it. How do I make the menu appear on all pages?. I have assigned the menu module I have created in joomla to all pages but no ;ick
2)How do I add effects to joomla modules so that the module content eases in as the user scrolls?
3)How to switch back to the old UI of Themler?
Hello, First of all I am a themler noob and have been using your software only a couple of days. I have a few questions about the software 1)I have run into a problem with using your joomla template feature. I have created a joomla horizontal menu and have placed it on the home page of the template. I hasve exported the template, installed it on joomla and created a new menu item called test to see if the menu appears. To my surprise I could not see it. How do I make the menu appear on all pages?. I have assigned the menu module I have created in joomla to all pages but no ;ick 2)How do I add effects to joomla modules so that the module content eases in as the user scrolls? 3)How to switch back to the old UI of Themler?
Support Team posted this 10 March 2016
  1. Please provide an access to your site so we could review the settings.
  2. Play around with the Extensions. Use the Block >> Extension >> Animation options for the desired module position.
  3. Unfortunately there is no such possibility.
Hi, 1. Please provide an access to your site so we could review the settings. 2. Play around with the Extensions. Use the Block >> Extension >> Animation options for the desired module position. 3. Unfortunately there is no such possibility. Sincerely, Hella
nthusiastic2learn
nthusiastic2learn posted this 11 March 2016
Thank you for your help with the animayion options. I will try it. I have figured out the menu issue by reading your documentation. Thanks again. Also please consider allowing exporting of the content and template(quickstart package) instead of just the template in future updTES. It will help us save a lot of time
Support Team posted this 11 March 2016
Thanks for the suggestion.
We'll be waiting for your results.
Hi, Thanks for the suggestion. We'll be waiting for your results. Sincerely, Hella
