I need to recover my themes from an old instal
denardodesign
denardodesign posted this 08 March 2016
Hello I made a them that worked great but i need to adjust it but sadly i crashed my old instal of windows. is there anyway to recover the them to edit ?
8 Comments
Support Team posted this 09 March 2016
Have you installed the theme on the site? If you have exported the theme with the editor included and installed it on the site, then you can open it in Themler. In other case I'm not sure what to suggest, maybe some hard drive recovery applications would help.
Hi, Have you installed the theme on the site? If you have exported the theme with the editor included and installed it on the site, then you can open it in Themler. In other case I'm not sure what to suggest, maybe some hard drive recovery applications would help. Sincerely, Hella
denardodesign
denardodesign posted this 31 March 2016
Ok great
How do i find the theamler file ? what will it be named and where will it be in the templet or wordpress ftp?
Ok great How do i find the theamler file ? what will it be named and where will it be in the templet or wordpress ftp?
Support Team posted this 01 April 2016
There should be export and preview folders inside the theme.
Hi, There should be export and preview folders inside the theme. Sincerely, Hella
denardodesign
denardodesign posted this 01 April 2016
Ok
So how do i open it with the mac themeler app?
Ok So how do i open it with the mac themeler app?
denardodesign
denardodesign posted this 05 April 2016
Hello can you pleas help me?
I need to be able to back up my projects externally and reopen them. pleas tell me how to open these files. Thank you!!
Hello can you pleas help me? I need to be able to back up my projects externally and reopen them. pleas tell me how to open these files. Thank you!!
Support Team posted this 06 April 2016
If you have exported the themes with the editor included you can now open them in Themler. Run Themler for the appropriate CMS you built the theme for and in the File menu choose import from ZIP.
Hi, If you have exported the themes with the editor included you can now open them in Themler. Run Themler for the appropriate CMS you built the theme for and in the File menu choose import from ZIP. Sincerely, Hella
Cotvi
Cotvi posted this 17 December 2016
If I reinstalled the system, but I have preserved the entire contents of the old drive C. Am I able to recover the old settings and themes?
Is the only way is the recovery projects, with previously saved projects in ZIP format?
If I reinstalled the system, but I have preserved the entire contents of the old drive C. Am I able to recover the old settings and themes? Is the only way is the recovery projects, with previously saved projects in ZIP format?
The theme folders should be stored on the C drive, the path is similar toC:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress, a separate folder for each CMS. Please note that ProgramData is usually a hidden folder.
Hello, The theme folders should be stored on the C drive, the path is similar to`C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`, a separate folder for each CMS. Please note that ProgramData is usually a hidden folder. Sincerely, Nettie, BillionDigital Team
