Please make the fixed position control editable to changes in responsive
shaulhadar
shaulhadar posted this 29 January 2015
Hello themler Team.
In one of my sites, i have a header that is a row , and it is fixed, so it stays on top, which is great.
My problem is that in responsive mode, when i turn off the element from begin fixed, it turns of also the desktop mode.
So my wish is that the fixed position can be different on responsive modes...
I hope you understood what i mean,
Shaul.
Hello themler Team. In one of my sites, i have a header that is a row , and it is fixed, so it stays on top, which is great. My problem is that in responsive mode, when i turn off the element from begin fixed, it turns of also the desktop mode. So my wish is that the fixed position can be different on responsive modes... I hope you understood what i mean, Thanks, Shaul.
Support Team posted this 29 January 2015
HI Shaul,
thank you for your suggestion. We'll consider it.
HI Shaul, thank you for your suggestion. We'll consider it. regards, Aileen
Shaul,
If you mean Fix on Screen effect it is not so easy to disable this effect only for one specific responsive mode, because this requires custom coding.
You can make your Row smaller in responsive or even hide it in responsive mode.
And create separate row for responsive mode that is not fixed and hide it for all other modes.
Oleg
Shaul, If you mean **Fix on Screen** effect it is not so easy to disable this effect only for one specific responsive mode, because this requires custom coding. You can make your **Row** smaller in responsive or even hide it in responsive mode. And create separate row for responsive mode that is not fixed and hide it for all other modes. Thanks, Oleg
shaulhadar
Hi Oleg, thanks, that sounds like a good workaround. I already made a few of those edits in a number of sites, because i had to edit there another row only for the responsive menu to show , so i guess it will be the same idea.
Thanks man :)
Shaul.
Hi Oleg, thanks, that sounds like a good workaround. I already made a few of those edits in a number of sites, because i had to edit there another row only for the responsive menu to show , so i guess it will be the same idea. Thanks man :) Shaul.
