Magento - Themler 'Edit' not loading
Pixel Web Serv
Pixel Web Serv posted this 24 March 2016
I reacently installed magento and themler, following the steps sugested on the site, everything is ok, except for the BillionTheme - Edit - section, it loads a blank page. Could there be a certain permision i need to give a certain file? I have done so and also all the Cache Management and everything else, Yet nothing works.
Support Team posted this 25 March 2016
Please follow the instructions:
http://answers.themler.com/articles/65488/
If that does not help, you can provide an access to your site so we could check the issue.
Hi, Please follow the instructions: http://answers.themler.com/articles/65488/ If that does not help, you can provide an access to your site so we could check the issue. Sincerely, Hella
enyonam
enyonam posted this 06 May 2017
What I get is was blocked due to MIME type mismatch
What I get is `was blocked due to MIME type mismatch`
Support Team posted this 11 May 2017
Sorry for delay. Please make sure that the user and group running on the web server are granted the appropriate read, write and execute (linux only) permissions on the following folders, as well as read and write permission on the files in these folders. For all these folders, subfolders and files in them.
 /app/code/local/
 /app/etc/
 /app/design/frontend/default/
 /skin/frontend/default/
 /var/
Also please check all the following settings:
http://answers.themler.com/articles/65518/themler-themes-issues-magento
Let us know if the issue is still present.
BilionDigital Team
Hello, Sorry for delay. Please make sure that the user and group running on the web server are granted the appropriate read, write and execute (linux only) permissions on the following folders, as well as read and write permission on the files in these folders. For all these folders, subfolders and files in them. /app/code/local/ /app/etc/ /app/design/frontend/default/ /skin/frontend/default/ /var/ Also please check all the following settings: http://answers.themler.com/articles/65518/themler-themes-issues-magento Let us know if the issue is still present. Sincerely, Nettie, BilionDigital Team
