What is the difference between a "Static" template and a "WP DATA" one?
shaulhadar
shaulhadar posted this 11 June 2014
Hello, I saw that some themes have a label under them which is written "Static" and some themes have the label "WP DATA".
Could you please explain to me what is the difference between them?
Thank you so much...
Hello, I saw that some themes have a label under them which is written "Static" and some themes have the label "WP DATA". Could you please explain to me what is the difference between them? Thank you so much...
Support Team posted this 11 June 2014
Hi Shaul,
Thanks for the question. I assume that it will be useful for other users.
When the Static label is set, that means that the template was completely created in Themler and the content was added manually.
When it says that the template is with the WP data, then the content was added in WP admin panel and can be edited from there. Themler allows to load the real content from your WP site in order to see how the site will look like when edited.
Hi Shaul, Thanks for the question. I assume that it will be useful for other users. When the Static label is set, that means that the template was completely created in Themler and the content was added manually. When it says that the template is with the WP data, then the content was added in WP admin panel and can be edited from there. Themler allows to load the real content from your WP site in order to see how the site will look like when edited. Sincerely, BillionDigital Team
