Make List view default in woocommerce
Wessmith
Wessmith posted this 01 April 2016
Is there a way to set the list view as default for product view in woo commerce. Or can you give me the code and I will add it myself.
Thanks!
Is there a way to set the list view as default for product view in woo commerce. Or can you give me the code and I will add it myself. Thanks!
14 Comments
Stagger Lee posted this 01 April 2016
Not easy. If you need it beyond any reason when theme is finished change it in script.js (around line 2200). Any edit in Theme will roll it back to default grid.
Plugins for this wont work either, because Themler has very specific CSS classes and HTML layout.
Not easy. If you need it beyond any reason when theme is finished change it in script.js (around line 2200). Any edit in Theme will roll it back to default grid. Plugins for this wont work either, because Themler has very specific CSS classes and HTML layout.
Wessmith
Do you happen to know what I need to add around line 2200? Or what I need to change it to? Everything I tried does not seem to be changing anything.
Seems as it is browser cookie based. Each time you change something delete cookies in browser settings.
Wessmith
Wessmith posted this 02 April 2016
Nope still won't work. I really need this to work.
Stagger Lee posted this 02 April 2016
If you dont need grid and view switch button there is simple 2 lines CSS trick.
I will check later how it is done by changing theme core files.
If you dont need grid and view switch button there is simple 2 lines CSS trick. I will check later how it is done by changing theme core files.
script.js:
var activeLayoutType = $.cookie('layoutType') || 'list',
        activeLayoutTypeSelector = $.cookie('layoutSelector') || '.separated-item-5.list';
category_products_x.php:
$cart_item = isset($cart_item) ? $cart_item : array();
                            $cart_item_key = isset($cart_item_key) ? $cart_item_key : '';
                            $product_view['dafaultLayoutName'] = "list";
script.js: var activeLayoutType = $.cookie('layoutType') || 'list', activeLayoutTypeSelector = $.cookie('layoutSelector') || '.separated-item-5.list'; category_products_x.php: $cart_item = isset($cart_item) ? $cart_item : array(); $cart_item_key = isset($cart_item_key) ? $cart_item_key : ''; $product_view['dafaultLayoutName'] = "list";
Wessmith
I don't need grid and view switch button, I just need list view. I added the js but it didn't make a difference. The php script made the catalog disappear. If there is a way to do this with css, please enlighten me. My client is amendment about it only being list view and did not tell me until I built it.
Stagger Lee posted this 03 April 2016
.woocommerce-page .separated-grid.row .list { display: block !important;}
.woocommerce-page .separated-grid.row .grid { display: none !important;}
Remove buttons in Themler, it is just one column.
.woocommerce-page .separated-grid.row .list { display: block !important;} .woocommerce-page .separated-grid.row .grid { display: none !important;} Remove buttons in Themler, it is just one column.
Support Team posted this 03 April 2016
the default grid output is hardcoded in theme code.
I'll contact developers about possible solution and will let you know.
Hello, the default grid output is hardcoded in theme code. I'll contact developers about possible solution and will let you know. regards, Aileen
Wessmith
Wessmith posted this 03 April 2016
Worked like a charm! Thank you Stagger!!!!!
kizzab77
kizzab77 posted this 04 August 2017
So glad I have found this! What is the file name that needs to be edited with the above code
Wessmith
Wessmith posted this 05 August 2017
It would be your themes style sheet, usually style.css.
engels
engels posted this 20 February 2018
Yeah, put these two lines of code into ADDITIONAL CSS and remove the control Products Type (the switcher buttons).
That seems to work. Without running into the issue of overwriting that code if update/save themler theme again.
Yeah, put these two lines of code into ADDITIONAL CSS and remove the control Products Type (the switcher buttons). That seems to work. Without running into the issue of overwriting that code if update/save themler theme again.
ZCompany
ZCompany posted this 17 July 2018
It breaks Product Slider - because of .woocommerce-page .separated-grid.row .grid { display: none !important;}
Product Slider doesn't show any products.
It breaks Product Slider - because of .woocommerce-page .separated-grid.row .grid { display: none !important;} Product Slider doesn't show any products.
