Lightbox in HTML5 project
matik_n
matik_n posted this 08 April 2016
Can you tell me when i find the lightbox on option in html5 project. I need this to my gallery
Hello Can you tell me when i find the lightbox on option in html5 project. I need this to my gallery
11 Comments
Support Team posted this 12 April 2016
this option is not available in HTML themes.
If you find ready to use solution on web we'll help you to incorporate it into Themler theme.
Hello, this option is not available in HTML themes. If you find ready to use solution on web we'll help you to incorporate it into Themler theme. regards, Aileen
matik_n
matik_n posted this 11 May 2016
Please ADD the Lightbox option or diffrent gallery to the themler HTML 5. much of this is sadly lacking
Support Team posted this 12 May 2016
we do have such request in our wish list. However I cannot say when it will be added.
Hello, we do have such request in our wish list. However I cannot say when it will be added. regards, Aileen
matik_n
matik_n posted this 29 May 2016
Thank You so much
Thank You so much
Support Team posted this 30 May 2016
ideosiete
ideosiete posted this 25 August 2016
May exist some way in order to doit?.
ideosiete
hELLO matik_n maybe you can solveit with this http://lokeshdhakar.com/projects/lightbox2/ i hoy you can doit. :)
matik_n
matik_n posted this 25 August 2016
i was try to enter this but is hard form me to implode.
Seppe
Seppe posted this 22 November 2016
Good morning
I have the same problem.
The funny thing is: when I export my html files, there IS a lightbox.css file and the code for the stylesheet and javascript is already in the source-code
How can you explain this??
I also tried to import the code for lightbox, but where I want it, it's a photoblock-section, so it won't work....
Good morning I have the same problem. The funny thing is: when I export my html files, there IS a lightbox.css file and the code for the stylesheet and javascript is already in the source-code How can you explain this?? I also tried to import the code for lightbox, but where I want it, it's a photoblock-section, so it won't work....
Support Team posted this 22 November 2016
The structure of the theme is different and the lightbox does not work in HTML themes. Please use the solutions provided above.
Hi, The structure of the theme is different and the lightbox does not work in HTML themes. Please use the solutions provided above. Sincerely, Hella
christopher
christopher posted this 28 June 2017
There is a CSS only Lightbox for HTML 5 projects by Gregory Schier (https://codepen.io/gschier/#) Be sure to give him credit and a backlink in your footer. Its the least one can do. His code really pulled my chestnuts out of the fire.
CSS Lightbox by Gregory Schier:
https://codepen.io/gschier/pen/HCoqh
There is a CSS only Lightbox for HTML 5 projects by Gregory Schier (https://codepen.io/gschier/#) Be sure to give him credit and a backlink in your footer. Its the least one can do. His code really pulled my chestnuts out of the fire. **CSS Lightbox by Gregory Schier:** https://codepen.io/gschier/pen/HCoqh
