Themler does not start err_connection_refused
lawrence5
lawrence5 posted this 09 April 2016
OK, I do not have an anti virus running and I disabled the firewall and Themler won't start. IT DID earlier in the day. I have attached a debug file. Any help would be appreciated. I DO have an Internet connection.
15 Comments
lawrence5
OK, I reinstalled the latest and I appear to be back up and running. Although a there was a php error on startup, I am back on my Joomla theme.
Support Team posted this 11 April 2016
Ok, please let us know if PHP error appears again and in this case also provide the log from Themler Diagnostics and theme package.
Hello, Ok, please let us know if PHP error appears again and in this case also provide the log from Themler Diagnostics and theme package. Sincerely, Nettie, BillionDigital Team
john9871j
john9871j posted this 08 September 2016
I am having ERR_CONNECTION_REFUSED problem in my pc..
Support Team posted this 08 September 2016
Hi John,
Please feel free to create new private ticket and describe your issue there in some more detail.
Ivan
Hi John, Please feel free to create new private ticket and describe your issue there in some more detail. Thanks, Ivan
john9871j
john9871j posted this 09 September 2016
I search on this topic and got the fix as you can see
http://www.deskdecode.com/err_connection_refused/]http://www.deskdecode.com/err_connection_refused/
but the thing is I cant able to reapir my computer with that fix and it my my internet connection dumbed
so now i cant able to use my internet
does anybody know where i did wrong.
I search on this topic and got the fix as you can see http://www.deskdecode.com/err_connection_refused/]http://www.deskdecode.com/err_connection_refused/ but the thing is I cant able to reapir my computer with that fix and it my my internet connection dumbed so now i cant able to use my internet does anybody know where i did wrong.
Support Team posted this 09 September 2016
Maybe you did something wrong in the connection settings. You can contact your internet provider for help.
Hi, Maybe you did something wrong in the connection settings. You can contact your internet provider for help. Sincerely, Hella
john9871j
john9871j posted this 10 September 2016
i'm doomed
> I search on this topic and got the fix as you can see > http://www.deskdecode.com/err_connection_refused/ > > but the thing is I cant able to reapir my computer with that fix and it my my internet connection dumbed > > so now i cant able to use my internet > > does anybody know where i did wrong. i'm doomed
Support Team posted this 12 September 2016
The solution may be not universal, so it would be better to revert changes back. If Themler still does not run, please let us know.
Hello, The solution may be not universal, so it would be better to revert changes back. If Themler still does not run, please let us know. Sincerely, Nettie, BillionDigital Team
techinpost
techinpost posted this 09 May 2017
I found a webpage from which i get rid out of this type of error issue, now you can also check this once for
getting rid of it completely from here: http://www.techinpost.com/fix-error-err_connection_refused-code-problem
I found a webpage from which i get rid out of this type of error issue, now you can also check this once for getting rid of it completely from here: [http://www.techinpost.com/fix-error-err_connection_refused-code-problem][1] [1]: http://www.techinpost.com/fix-error-err_connection_refused-code-problem
Support Team posted this 10 May 2017
techinpost,
Thanks for sharing the solution. Additionally, we would like to add that this issues in Themler can also be related to some antivirus program or some other third-party application.
**techinpost**, Thanks for sharing the solution. Additionally, we would like to add that this issues in Themler can also be related to some antivirus program or some other third-party application. Sincerely, Nettie, BillionDigital Team
dgthyyy
dgthyyy posted this 18 June 2017
You can fix this error by finding right cause windows firewalls, LAN settings . For windows firewall try below.
  1. Get into Control Panel
  2. Now just check out on headings.
  3. Simply click on windows firewall.
  4. And turn of f windows firewall
If problem still appearing then visit and follow this solutions for more.
You can fix this error by finding right cause windows firewalls, LAN settings . For windows firewall try below. 1. Get into Control Panel 2. Now just check out on headings. 3. Simply click on windows firewall. 4. And turn of f windows firewall If problem still appearing then visit and [follow this][1] solutions for more. [1]: https://www.howtoseeks.com/err_connection_refused/
geekswizard
geekswizard posted this 10 July 2017
yes you can fix this error
Simply click on windows firewall or your anti virus firewall
And turn it off.
here is the solution
yes you can fix this error Get into Control Panel Now just check out on headings. Simply click on windows firewall or your anti virus firewall And turn it off. [here is the solution][1] [1]: http://www.geekswizard.com/fix-err-spdy-protocol-error/
tutoweb
tutoweb posted this 04 August 2017
hello,
you can fix this issue very easily. just visit here to fix this issue. Here you will be get full tuto about this issue.
hello, you can fix this issue very easily. just visit here to [fix this issue][1]. Here you will be get full tuto about this issue. [1]: https://www.themaxweb.com/fix-error_spdy_protocol_error-in-google-chrome/
234tanveerkhan
234tanveerkhan posted this 04 November 2017
i found the solution here https://technofizi.net/how-to-solve-err_connection_refused/
fawad.getful
fawad.getful posted this 4 weeks ago
thanks for fixing all issues now its fine for me. windows 10 activator
thanks for fixing all issues now its fine for me. [windows 10 activator][1] [1]: https://profullcrack.com/windows-10-activator-kmspico-all-version/
