Copy style
jstringer6nr6
jstringer6nr6 posted this 15 April 2016
Hi Good morning,
I am working on this site at the moment http://falcontest.co.uk/about-school/aims-and-values
My question is ... how can i easily style the twitter feed module on the right so that it is exactly the same as the vertical menu on the lift?
The copy style option appears "greyed out" for me
Jonathan.
Hi Good morning, I am working on this site at the moment http://falcontest.co.uk/about-school/aims-and-values My question is ... how can i easily style the twitter feed module on the right so that it is exactly the same as the vertical menu on the lift? The copy style option appears "greyed out" for me Regards, Jonathan.
Stagger Lee posted this 15 April 2016
You cant. Very different HTML output. You can give Twitter module blue background. Maybe some other things, but I am not sure now.
Support Team posted this 19 April 2016
As I can see this is block in the Joomla position control. You can style the block:
But this will style only the wrapper. The content inside cannot be styles because this is iframe.
Hi, As I can see this is block in the Joomla position control. You can style the block: !position-block.png! But this will style only the wrapper. The content inside cannot be styles because this is iframe. Thank you, Olivia
