ERROR In Magento: Empty slider settings. Please do "Apply Theme to Cms" and configure "Slider 1" in Admin panel.
William OW
William OW posted this 09 February 2015
HI,
I'm getting the following error on home page after installing the theme on Magento 1.9.1.0 :
PS: Just finished installing magento.
Also, I want to achieve exact HOME PAGE design with magento at http://i1878232.magento.20.preview1-live.billiondigital.com/. Is it possible to IMPORT the content from the theme? If not please provide some instructions on how to achieve that design.
Please help,
-William
HI, I'm getting the following error on home page after installing the theme on Magento 1.9.1.0 : Empty slider settings. Please do "Apply Theme to Cms" and configure "Slider 1" in Admin panel. PS: Just finished installing magento. Also, I want to achieve exact HOME PAGE design with magento at http://i1878232.magento.20.preview1-live.billiondigital.com/. Is it possible to IMPORT the content from the theme? If not please provide some instructions on how to achieve that design. Please help, -William
Support Team posted this 09 February 2015
William,
  1. Re: configure "Slider 1" in Admin panel
    Please configure Product Slider in your Magento CMS.
    This option cannot moved between sites.
    http://answers.billiondigital.com/articles/4780/product-slider-ecommerce
  2. You can try to use Magento Import/Export to move products:
    http://www.magentocommerce.com/knowledge-base/entry/tutorial-using-magentos-import-export-
    But you cannot move Categories, this requires special plug-ins.
  3. Theme design
    Please click FILE > Download Theme as ZIP from the top menu.
    And install this theme to your CMS.
    http://answers.billiondigital.com/articles/3825/how-to-install-magento-theme
Oleg
William, 1. Re: configure "Slider 1" in Admin panel Please configure **Product Slider** in your Magento CMS. This option cannot moved between sites. http://answers.billiondigital.com/articles/4780/product-slider-ecommerce 2. You can try to use Magento Import/Export to move products: http://www.magentocommerce.com/knowledge-base/entry/tutorial-using-magentos-import-export- But you cannot move Categories, this requires special plug-ins. 3. Theme design Please click **FILE** > **Download Theme as ZIP** from the top menu. And install this theme to your CMS. http://answers.billiondigital.com/articles/3825/how-to-install-magento-theme Thanks, Oleg
Support Team posted this 13 March 2015
Sorry for the delay.
how to add a banner slider on magento 1.9.1.0 ????
It depends on what exactly banner you want to create. Could you please explain your question in more details and provide us with an example?
Is it should be a Slider with products, or static slideshow, etc?
Hi, Sorry for the delay. > how to add a banner slider on magento 1.9.1.0 ???? It depends on what exactly banner you want to create. Could you please explain your question in more details and provide us with an example? Is it should be a Slider with products, or static slideshow, etc? Thank you, Olivia
info2349
info2349 posted this 11 June 2016
If I have made two slides slider and two slider images in Themler view: then your instruction does not tell me what to do (http://answers.themler.com/articles/4780/product-slider-ecommerce) with magento.
I get the error on Themler: Empty slider settings. Please do "Apply theme to CMS" and configure slider. But I do not get the answer from you. Step to step: what to do??
If I have write the image text in Themler and downloaded an image to the slider in themler:
1) do I have to do nothing or is the slider going to work when I´m bringing the template css to my real magento site? The slider is just in front-page.
2) Are my made images then there in my made Themler Template?
3) And is the slider also already there with my themler made images? --> With what code I get the slider to work on front page?
Proper replies please.
Kati
If I have made two slides slider and two slider images in Themler view: then your instruction does not tell me what to do (http://answers.themler.com/articles/4780/product-slider-ecommerce) with magento. I get the error on Themler: Empty slider settings. Please do "Apply theme to CMS" and configure slider. But I do not get the answer from you. Step to step: what to do?? If I have write the image text in Themler and downloaded an image to the slider in themler: 1) do I have to do nothing or is the slider going to work when I´m bringing the template css to my real magento site? The slider is just in front-page. 2) Are my made images then there in my made Themler Template? 3) And is the slider also already there with my themler made images? --> With what code I get the slider to work on front page? Proper replies please. Kati
Support Team posted this 16 June 2016
This is not error. This is a message that describes what to do.
The provided link contains instruction for different CMSs including Magento. Here is direct link to the chapter about Magento:
http://answers.themler.com/articles/4780/product-slider-ecommerce#magento
You just need to add control and choose the source for the Slider. That's all.
Hi, > I get the error on Themler: Empty slider settings. Please do "Apply theme to CMS" and configure slider. But I do not get the answer from you. Step to step: what to do?? This is not error. This is a message that describes what to do. The provided link contains instruction for different CMSs including Magento. Here is direct link to the chapter about Magento: http://answers.themler.com/articles/4780/product-slider-ecommerce#magento You just need to add control and choose the source for the Slider. That's all. Thank you, Olivia
info2349
info2349 posted this 17 June 2016
Well... Actually I didn´t have to do nothing. I just installed the magento skin and the dia and the front-page is working as it should be. That is logical and how it should be :)
I just ignored those two lines.
Could say that years using Artisteer is helping in making these, but you have to know what magento is and how it is made so you can make your own templates. This would have been easier for me if I had just started to make the skin and not to try to look at the instructions :) But now I know.
Kati
Hello, Well... Actually I didn´t have to do nothing. I just installed the magento skin and the dia and the front-page is working as it should be. That is logical and how it should be :) I just ignored those two lines. Could say that years using Artisteer is helping in making these, but you have to know what magento is and how it is made so you can make your own templates. This would have been easier for me if I had just started to make the skin and not to try to look at the instructions :) But now I know. Kati
Support Team posted this 17 June 2016
Hi, Please let us know if you have any further questions. Thank you, Olivia
Support Team posted this 31 October 2017
Exactly what steps you followed?
The "Apply theme to CMS" is now "Save" or "Publish". Simply save changes and configure Slider under the Magento Admin Panel
http://answers.themler.io/articles/4780/product-slider-ecommerce
Hi, Exactly what steps you followed? The "Apply theme to CMS" is now "Save" or "Publish". Simply save changes and configure Slider under the Magento Admin Panel http://answers.themler.io/articles/4780/product-slider-ecommerce Thank you, Olivia
