Header shifting error on page reload
Jwhissell
Jwhissell posted this 16 April 2016
Every time a page reloads or has an element load later down the page the header goes all out of wack (see image). How can this be fixed?
9 Comments
Stagger Lee posted this 17 April 2016
I experienced this yesterday after last update. All works OK on frontend, some glitch in edit screen.
Save all work and click F5, maybe delete App cache. Something like this, dont remember now. I know I did nothing special.
Click on problematic element and go again to Home tab. There click on width (3 options) again untill it fixed itself.
I experienced this yesterday after last update. All works OK on frontend, some glitch in edit screen. Save all work and click F5, maybe delete App cache. Something like this, dont remember now. I know I did nothing special. Click on problematic element and go again to Home tab. There click on width (3 options) again untill it fixed itself.
Jwhissell
Jwhissell posted this 17 April 2016
That unfortunately did not work for me. The issue is also more wide spread for me. It happens both on front end and backend (in the editor)
BillyBob
BillyBob posted this 17 April 2016
I have same the issue. Posted in THIS thread about 6 days ago. The HMENU loads in a weird position if you're scrolled down on page on reload, or in editor when you're scrolled down and make a change, or if you link to an anchor that's down on page (below header view-able area). When you scroll back up to the top of the page, the HMENU 're-sticks' to the top and appears normal and becomes fixed on scroll again. You're issue the same?
I re-posted this issue and another issue that comes up in Joomla 3.5.1 and full page width modules HERE, and a request to get some more support assistance.
I have same the issue. Posted in [THIS][1] thread about 6 days ago. The HMENU loads in a weird position if you're scrolled down on page on reload, or in editor when you're scrolled down and make a change, or if you link to an anchor that's down on page (below header view-able area). When you scroll back up to the top of the page, the HMENU 're-sticks' to the top and appears normal and becomes fixed on scroll again. You're issue the same? I re-posted this issue and another issue that comes up in Joomla 3.5.1 and full page width modules [HERE][2], and a request to get some more support assistance. [1]: http://answers.themler.com/questions/72873/hmenu-fixed-on-scroll-acting-funny [2]: https://answers.themler.com/questions/73962/display-issues-and-support
Jwhissell
The same issue you're having sounds like what I'm having. It only happens on page reload or during an achor action. To fix it you have to scroll all the way back up and then it resets... But it's still a bug that needs to be fixed... It does not look good when it happens on the end users side.
BillyBob
Agreed. I thought maybe this bug would get fixed with April 16th update, but it didn't. The Issue basically takes away our option to 'fix menu on scroll'. I need that option, it reduces your bounce rate (important to SEO) and overall makes for a better user experience.
Another issue that I'm having that I think is related to this issue, it that on mobile, I cannot get HMENU to fix on scroll. Same with you?
Agreed. I thought maybe this bug would get fixed with April 16th update, but it didn't. The Issue basically takes away our option to 'fix menu on scroll'. I need that option, it reduces your bounce rate (important to SEO) and overall makes for a better user experience. Another issue that I'm having that I think is related to this issue, it that on mobile, I cannot get HMENU to fix on scroll. Same with you?
Jwhissell
I'm able to fix my HMENU on scroll for mobile.
Sorry for the delay. I could help you with that if you could provide an access to your site back end. So please create a private topic with the site login and also mention that it s related to this ticket.
Hi, Sorry for the delay. I could help you with that if you could provide an access to your site back end. So please create a private topic with the site login and also mention that it s related to this ticket. Sincerely, Hella
Josh
Josh posted this 11 May 2017
What was the fix on this? I am having the same issue
Support Team posted this 12 May 2017
Commonly the issue is that the Sticky extension is enabled for several controls that are positioned one inside another. Like for the Header and Menu. In this case please leave the extension for the top level control only, Header for example.
Hi, Commonly the issue is that the Sticky extension is enabled for several controls that are positioned one inside another. Like for the Header and Menu. In this case please leave the extension for the top level control only, Header for example. Sincerely, Hella
