Anchor links
williamvanveen1988
williamvanveen1988 posted this 19 April 2016
Dear Support,
I have some anchor links as menu buton but when i click on the menu item it covers over the start.
check:
http://deregelaar.wveen.com/home#contact
You know some solition for this?
Kind regards,
William
Dear Support, I have some anchor links as menu buton but when i click on the menu item it covers over the start. check: http://deregelaar.wveen.com/home#contact You know some solition for this? Kind regards, William
Support Team posted this 20 April 2016
The anchor is loaded on the top of the screen, that is the standard behavior. You can add additional padding in each section so the content will go down a bit to be seen under the header.
Hi, The anchor is loaded on the top of the screen, that is the standard behavior. You can add additional padding in each section so the content will go down a bit to be seen under the header. Sincerely, Hella
