How Can I add a Transparent Texture to the site background?
shaulhadar
shaulhadar posted this 13 June 2014
Hello, in artisteer there was an option to add a texture and set its opacity on all sorts of elements, here i can see only an option for an image, I can't see any option for putting a texture, and than changing it's opacity.... Is there any way to do it perhaps?
Thanks....
Hello, in artisteer there was an option to add a texture and set its opacity on all sorts of elements, here i can see only an option for an image, I can't see any option for putting a texture, and than changing it's opacity.... Is there any way to do it perhaps? Thanks....
Support Team posted this 13 June 2014
Hi Shaul,
Currently there are options to set Transparency for Background Fill and Gradient, however the custom image is uploaded as it is (no matter if it has some opacity or not). For now I would recommend you to use an image editor and set transpency for each custom image there if needed. We will consider this feature to be implemented in future.
Hi Shaul, Currently there are options to set Transparency for Background Fill and Gradient, however the custom image is uploaded as it is (no matter if it has some opacity or not). For now I would recommend you to use an image editor and set transpency for each custom image there if needed. We will consider this feature to be implemented in future. Thank you, BillionDigital Team
shaulhadar
shaulhadar posted this 25 September 2014
Hi, thanks for that. This can be a really great feature. if a designer could edit the row's color, and than add a texture above it, than it would let to make more premium looking sites with themeler.
Thanks for your time,
Shaul.
Hi, thanks for that. This can be a really great feature. if a designer could edit the row's color, and than add a texture above it, than it would let to make more premium looking sites with themeler. Thanks for your time, Shaul.
Support Team posted this 26 September 2014
Could you please explain your request a little?
Currently Row control supports adding background images over the fill color.
Or you're still referring to the Texture transparency option?
Hello > This can be a really great feature. if a designer could edit the row's color, and than add a texture above it Could you please explain your request a little? Currently Row control supports adding background images over the fill color. Or you're still referring to the Texture transparency option? Thank you, Olivia
