Responsive Menu Problem
shaulhadar
shaulhadar posted this 13 June 2014
Hi, I have found that if you put a menu in the header, than look at it in responsive view, it doesn't open correctly, but if you put the menu outside of the header, it will work properly and will push the content under it like it should....
Please fix this...
Shaul.
Hi, I have found that if you put a menu in the header, than look at it in responsive view, it doesn't open correctly, but if you put the menu outside of the header, it will work properly and will push the content under it like it should.... Please fix this... Thanks, Shaul.
6 Comments
Support Team posted this 13 June 2014
Shaul,
Thank you.
This bug is confirmed and will be fixed soon.
Shaul, Thank you. This bug is confirmed and will be fixed soon.
BTW, this is how Bootstrap 3 by default works,
but it's possible to fix.
BTW, this is how Bootstrap 3 by default works, but it's possible to fix.
Support Team posted this 08 July 2014
Sorry for the delay.
The reported issue is fixed. We'll update Themler in the near future.
Thank you.
Hello Sorry for the delay. The reported issue is fixed. We'll update Themler in the near future. Thank you.
shaulhadar
shaulhadar posted this 25 September 2014
Hi, thanks for that :)
bsjelin
bsjelin posted this 02 February 2015
Hello - I am also running into this issue. I have my hmenu inside of my header, but it seems to be hidden behind other objects when viewed in responsive mode... I've tried pushing z-index but that doesnt help either. Is this an issue with the new "header" & "footer" options that were recently changed?
Support Team posted this 03 February 2015
Hi Brandon,
Could you please create a separate private ticket and provide a link to the problem theme?
Hi Brandon, Could you please create a separate private ticket and provide a link to the problem theme? Thank you, Olivia
