headline and slogan in joomla multilanguage
votruba
votruba posted this 21 April 2016
How to create a joomla headline and slogan for multiple languages. Or how slogan and headline used as translatable text (eg., Then translate using extensions / languages / overrides).
Thank you in advance for your reply and sorry for my english
How to create a joomla headline and slogan for multiple languages. Or how slogan and headline used as translatable text (eg., Then translate using extensions / languages / overrides). Thank you in advance for your reply and sorry for my english
Support Team posted this 22 April 2016
Multilanguage support for Slogan or Headline - is common problem.
Multiple solutions from Joomla community:
- If you place the headline / slogan in a module, you can assign a language to the module, so it will only appear with the desired language.
- You can override or insert your own keys when going to Extensions > Languages > Overrides. After that, you only need to put these keys into your site configuration.
- use custom code.
- language specific themplates: example .
Themler team
Hello, Multilanguage support for Slogan or Headline - is common problem. Multiple solutions from Joomla community: - If you place the headline / slogan in a module, you can assign a language to the module, so it will only appear with the desired language. - You can override or insert your own keys when going to Extensions > Languages > Overrides. After that, you only need to put these keys into your site configuration. - use [custom code][1]. - language specific themplates: [example][2] . - ... Regards, Themler team [1]: http://joomla.stackexchange.com/questions/7373/localization-of-site-title-headline-and-slogan [2]: http://multilingual.demojoomla.com/multi-lingual-steps-by-steps.html
