How Can I Add a Vertical Menu?
shaulhadar
shaulhadar posted this 13 June 2014
Hi, I am looking to add a vertical menu, i found the navigation elements, but I can't see any vertical menu in there. Is there any other way to add one?
Thanks....
Hi, I am looking to add a vertical menu, i found the navigation elements, but I can't see any vertical menu in there. Is there any other way to add one? Thanks....
Support Team posted this 13 June 2014
Hello Shaul,
Vertical menu should be created in a CMS so that it appears in Themler. Please follow these steps:
  1. Add Vertical Menu Control to any place in the Primary Widget Area where you want the Menu to appear.
  2. Publish changes and log-in to your WordPress Admin Panels.
  3. Create a regular WordPress Menu under Appearance - Menus.
  4. Go to Appearance - Widgets, drag and drop "Vertical Menu" widget to Primary Widget Area.
Design for the vertical menu can be set previously or after adding it, in PW -> Default Styles -> Vertical Menu. Highlight the Vertical menu that is already present in your theme, to set the styles for it.
Best regards,
Hello Shaul, Vertical menu should be created in a CMS so that it appears in Themler. Please follow these steps: 1. Add Vertical Menu Control to any place in the Primary Widget Area where you want the Menu to appear. 2. Publish changes and log-in to your WordPress Admin Panels. 3. Create a regular WordPress Menu under Appearance - Menus. 4. Go to Appearance - Widgets, drag and drop "Vertical Menu" widget to Primary Widget Area. Design for the vertical menu can be set previously or after adding it, in PW -> Default Styles -> Vertical Menu. Highlight the Vertical menu that is already present in your theme, to set the styles for it. Best regards, BillionDigital Team
Web IT Solutions LLP
Web IT Solutions LLP posted this 21 April 2017
Hi Sir,
This above process is for CMS & WordPress template.
What about HTML Project?
Please kindly share the steps for HTML Projects too.
Suffian Ahmed
Hi Sir, This above process is for CMS & WordPress template. What about HTML Project? Please kindly share the steps for HTML Projects too. Regards Suffian Ahmed
Support Team posted this 21 April 2017
In Themler for HTML it is suffiecient, to add the Vertical Menu control. We have also answered you in the other case.
Hello, In Themler for HTML it is suffiecient, to add the Vertical Menu control. We have also answered you in the other case. Sincerely, Nettie, BillionDigital Team
