Column shortcodes
dpdoolette
dpdoolette posted this 27 April 2016
Since the switch to 12 column layout, I find some of the column shortcodes do not work properly. In my case it is the [one-third] shortcode. I find my one third columns now occupy the full page width. If I change to using [column width="4"] instead all is fine. Are [one_third] etc still assuming a 24 column layout?
dpdoolette
I fell into a trap here. I transferred template to another joomla installation but did not realise I needed to update content plugins. A trap for the unwary.
Support Team posted this 27 April 2016
Sorry, please let me know if you still need our help or the template is working fine now?
Hi, Sorry, please let me know if you still need our help or the template is working fine now? Sincerely, Hella
dpdoolette
dpdoolette posted this 28 April 2016
Yes template is working fine. I notice that although you have moved to a 12 column layout that the column shortcodes when specifying widths still work on a 24 column layout. Will it stay that way?
Support Team posted this 04 May 2016
there seems to be an issue with shortcodes after the last update. We'll check it.
In the meantime please use workaround with [column width="4"]
Hello, there seems to be an issue with shortcodes after the last update. We'll check it. In the meantime please use workaround with [column width="4"] regards, Aileen
Support Team posted this 06 May 2016
just to let you know: this issue has been resolved on our end and the major fix will be included into the next Themler major update
Hello, just to let you know: this issue has been resolved on our end and the major fix will be included into the next Themler major update regards, Aileen
danny18
danny18 posted this 22 July 2016
I have constant problems with creating a second row of columns inside one Joomla article.
The second row of columns just doesn't work properly, and any text just above it gets cut off on the left side by about 5 pixels.
I have updated my themes and nothing has been resolved?
I have constant problems with creating a second row of columns inside one Joomla article. The second row of columns just doesn't work properly, and any text just above it gets cut off on the left side by about 5 pixels. I have updated my themes and nothing has been resolved?
Support Team posted this 22 July 2016
Could you please create a separate ticket with the access to the site back end and several marked screen shots demonstrating the issue.
Hi, Could you please create a separate ticket with the access to the site back end and several marked screen shots demonstrating the issue. Sincerely, Hella
