Insufficient permissions
9dade
9dade posted this 06 May 2016
Hello, my issue is with the following error: "Insufficient permissions", making it impossible for me to continue developing my work
already applied all the required permissions
How to solve? awaiting return
Hello, my issue is with the following error: "Insufficient permissions", making it impossible for me to continue developing my work already applied all the required permissions ![Insufficient permissions][1] [1]: https://scontent.fudi1-1.fna.fbcdn.net/v/t35.0-12/13184831_1106898812664687_1781782761_o.jpg?oh=e327e83577c775607fc0e2910cabfd3d&oe=572FCB45 How to solve? awaiting return
greg41
greg41 posted this 06 May 2016
Are you publishing locally to Windows server or remotely to some Linux box?
9dade
Is Solution
9dade posted this 07 May 2016
Hello, I am developing the site on a remote hosting server on Linux.
Support Team posted this 10 May 2016
Please make sure that you have proper folder permissions:
http://answers.themler.com/articles/3624/how-to-install-wordpress-theme >> Permissions.
Hi, Please make sure that you have proper folder permissions: http://answers.themler.com/articles/3624/how-to-install-wordpress-theme >> Permissions. Thank you, Olivia
bmericsson
bmericsson posted this 16 July 2016
I have the same problem. Sometimes its working without problem, and next time I have this Insufficient permissions. It means it has nothing to do with my tmp and path, cause it is correct.
Solved for me : )
When I install a new themplate to Joomla, no matter if its a template you should use or not, I can open it, and after that I can open the template I am using....
I have the same problem. Sometimes its working without problem, and next time I have this Insufficient permissions. It means it has nothing to do with my tmp and path, cause it is correct. Solved for me : ) When I install a new themplate to Joomla, no matter if its a template you should use or not, I can open it, and after that I can open the template I am using....
