VirtueMart Quantity Control Plus & Minus
Cats Eye
Cats Eye posted this 11 May 2016
Does anyone know where to fix the quantity controller + and - buttons for VM in Themler? Mine are blank but the functionality is working.
Thank you in advance :)
Hi Does anyone know where to fix the quantity controller + and - buttons for VM in Themler? Mine are blank but the functionality is working. Thank you in advance :)
Support Team posted this 11 May 2016
You have added the Product Quantity with the help of a shortcode, right? Please try to temporary disable all third-party plugins and check if the issue persists.
Also, did you please try adding Product Quantity control in Themler for Product Details? The issue is not reproducible for it.
Hello, You have added the Product Quantity with the help of a shortcode, right? Please try to temporary disable all third-party plugins and check if the issue persists. Also, did you please try adding Product Quantity control in Themler for Product Details? The issue is not reproducible for it. Sincerely, Nettie, BillionDigital Team
Cats Eye
What? What shortcode? There are no third party plugins.
This is a straight VM installation and that is the Product Quantity control in Themler.
What? What shortcode? There are no third party plugins. This is a straight VM installation and that is the Product Quantity control in Themler.
Hi Tanya,
I could not reproduce the issue with the Product Quantity control in Themler. Could you please attach the exported theme .zip for investigation?
Hi Tanya, I could not reproduce the issue with the Product Quantity control in Themler. Could you please attach the exported theme .zip for investigation? Sincerely, Nettie, BillionDigital Team
osangoqui
osangoqui posted this 06 October 2018
I have the same problem,
the virtuemart css is causing problems with my template, when I disable virtuemart css my template works correctly, but the product quantity - and + buttons disappear as described here.
I have the same problem, the virtuemart css is causing problems with my template, when I disable virtuemart css my template works correctly, but the product quantity - and + buttons disappear as described here.
