Please Explain the Difference Between Artisteer and Themler
TeachU
TeachU posted this 15 May 2016
I love Artisteer. Recently I found out my CMS is going out of business so I'm switching to all WordPress. Artisteer can make WordPress themes. What does Themler do?
Thank you.
Chris Reich
I love Artisteer. Recently I found out my CMS is going out of business so I'm switching to all WordPress. Artisteer can make WordPress themes. What does Themler do? Thank you. Chris Reich
Support Team posted this 15 May 2016
Themler also creates WP themes. Also it allows to create WooCommerce templates. In general, Themler is more powerful and also is better in responsive disugn. The difference is in the editing of the content. Artisteer is an offline application that exports content with the template that you can then install on the site. Themler allows editing of the live-time content. You install the Themler theme on your site and run the editor from your back end. That opens the application and allows you to edit content of the site as well.
Feel free to try the trial version. It does not allow saving, but you will see how it works within the editor. The same result will be on the site after saving.
Themler also has the desktop version where you can work offline like in Artisteer, but that does not export the content of the site, design only.
Hi, Themler also creates WP themes. Also it allows to create WooCommerce templates. In general, Themler is more powerful and also is better in responsive disugn. The difference is in the editing of the content. Artisteer is an offline application that exports content with the template that you can then install on the site. Themler allows editing of the live-time content. You install the Themler theme on your site and run the editor from your back end. That opens the application and allows you to edit content of the site as well. Feel free to try the trial version. It does not allow saving, but you will see how it works within the editor. The same result will be on the site after saving. Themler also has the desktop version where you can work offline like in Artisteer, but that does not export the content of the site, design only. Sincerely, Hella
TeachU
Thanks! I already have a paid Themler. It came with my Artisteer renewal but I just hadn't used it because I didn't understand it. But I played with it last night and I love it!!! Now that I'm using Word Press, I can see what the benefits of Themler are.
Thank you so much...
Chris
Thanks! I already have a paid Themler. It came with my Artisteer renewal but I just hadn't used it because I didn't understand it. But I played with it last night and I love it!!! Now that I'm using Word Press, I can see what the benefits of Themler are. Thank you so much... Chris
Support Team posted this 16 May 2016
Chris, you are welcome! Pleasse feel free to contact us if any questions appear in process.
Chris, you are welcome! Pleasse feel free to contact us if any questions appear in process. Sincerely, Nettie, BillionDigital Team
