How to parse shortcode absolutely everywhere in Themler theme
Stagger Lee posted this 15 May 2016
Just small snippet. You can add it to Docs, very useful.
Settings - Additional CMS Code.
add_filter('theme_body', 'do_shortcode');
Just small snippet. You can add it to Docs, very useful. Settings - Additional CMS Code. add_filter('theme_body', 'do_shortcode');
Support Team posted this 16 May 2016
Thank you for the input.
I've created a doc page:
- WP Tips and Tricks
And this is for Woocommerce and Virtuemart if needed:
- Woocommerce Tips and Tricks
- Virtuemart Tips and Tricks
Hi, Thank you for the input. I've created a doc page: - [WP Tips and Tricks](page:57268) And this is for Woocommerce and Virtuemart if needed: - [Woocommerce Tips and Tricks](page:67129) - [Virtuemart Tips and Tricks](page:67028) Thank you, Olivia
Stagger Lee posted this 16 May 2016
Oilvia, you can solve many Items from Wishlist with filters & actions. Just check how Customizr theme framework does it.
For instance your coders did not need to lose time on making an GUI option for showing icons in menu if parent item has subitems. They lost its time and this one is classic example for filters/actions for Settings - Additional CMS code.
Just write it in Docs and who needs it they are there.
Oilvia, you can solve many Items from Wishlist with filters & actions. Just check how Customizr theme framework does it. For instance your coders did not need to lose time on making an GUI option for showing icons in menu if parent item has subitems. They lost its time and this one is classic example for filters/actions for Settings - Additional CMS code. Just write it in Docs and who needs it they are there.
Support Team posted this 19 May 2016
Hello Stagger Lee,
thank you for your suggestion.
However now it is not possible to allow end users to customize and change more in Themler as they could do. It is related to Themler specific. But we'll pass the suggestion to our developer team to consider it
Hello Stagger Lee, thank you for your suggestion. However now it is not possible to allow end users to customize and change more in Themler as they could do. It is related to Themler specific. But we'll pass the suggestion to our developer team to consider it regards, Aileen
john106
john106 posted this 14 June 2016
This crashes Themler in our Joomla 3.5 template. After adding the code, we get
"Call to undefined function add_filter() - Joomla". Then a "PHP fatal error in the functions_additional.php on line 4. Call to undefined function add_filter()..."
> Just small snippet. You can add it to Docs, very useful. > Settings - Additional CMS Code. > > add_filter('theme_body', 'do_shortcode'); This crashes Themler in our Joomla 3.5 template. After adding the code, we get "Call to undefined function add_filter() - Joomla". Then a "PHP fatal error in the functions_additional.php on line 4. Call to undefined function add_filter()..."
Support Team posted this 17 June 2016
this is the WP specific code
You cannot add it to Joomla themes.
Hello, this is the WP specific code add_filter('theme_body', 'do_shortcode'); You cannot add it to Joomla themes. regards, Aileen
