Alt tag for images
ArturZ
ArturZ posted this 16 May 2016
How do I add an alt tag to the image background and images on the page.
I can not find a place to enter alt
I use the latest themler
Hi How do I add an alt tag to the image background and images on the page. I can not find a place to enter alt I use the latest themler
13 Comments
Support Team posted this 16 May 2016
Hi!
You can add Alt text in Image Tab -> Alt field.
Please look at the image below.
Best regards, Artem.
Hi! You can add Alt text in Image Tab -> Alt field. Please look at the image below. Best regards, Artem. !image-alt.jpg!
Just a follow up, this setting is available for the Image control and not for the background image.
Hi, Just a follow up, this setting is available for the Image control and not for the background image. Sincerely, Hella
ArturZ
Hi.
The problem is that I edit the template directly on the backend of Joomla.
This is the background image sections
See the following screenshot
Hi. The problem is that I edit the template directly on the backend of Joomla. This is the background image sections See the following screenshot !alt.jpg!
As I commented above, the option is available for the Image control and not the image added as the background. There is no possibility to add alt tag to the background images.
Hi, As I commented above, the option is available for the Image control and not the image added as the background. There is no possibility to add alt tag to the background images. Sincerely, Hella
ArturZ
Ok
Thanks for the answers
Artur
Ok Thanks for the answers Regards Artur
ArturZ
The last question in this thread.
When it is planned to add alt options for background images.
I greet and thank you for your help
Artur
The last question in this thread. When it is planned to add alt options for background images. I greet and thank you for your help Artur
Support Team posted this 18 May 2016
We do not have such plans now. Follow the news.
Hi, We do not have such plans now. Follow the news. Sincerely, Hella
ArturZ
ArturZ posted this 18 May 2016
OK thank you
OK thank you
You are welcome.
You are welcome.
smh_60
smh_60 posted this 09 February 2018
Does the same apply to adding alt tags to images inside a column. Seems that I cannot get the image selected to get the image menu open when it is inside a column.
Rgds
Sirpa
Hi, Does the same apply to adding alt tags to images inside a column. Seems that I cannot get the image selected to get the image menu open when it is inside a column. Rgds Sirpa
Support Team posted this 12 February 2018
If you have added the image in the column as the background, that is the same. it is added as the background-image property in CSS files and not like the img tag in the page. If you need it to be an img tag, then use the Image control to add the image into the column.
Hi, If you have added the image in the column as the background, that is the same. it is added as the `background-image` property in CSS files and not like the `img` tag in the page. If you need it to be an `img` tag, then use the Image control to add the image into the column. Sincerely, Hella
Stagger Lee posted this 12 February 2018
Search engine spiders rarely index and cache background images. So no point to bother and lose time for yourself.
