Add new slide to an existing slider
redmirc
redmirc posted this 17 May 2016
Dear all, i would like to add a new slide toban existing slider but unfortunately i cant add it through web themler application. An some one tell me how i can add a new slide using code editor?
Support Team posted this 18 May 2016
Click on the Slider within editor, the options for the slider will appear on the top ribbon and there will be an Add Slide option. Let us know if that does not work for you.
Hi, Click on the Slider within editor, the options for the slider will appear on the top ribbon and there will be an Add Slide option. Let us know if that does not work for you. Sincerely, Hella
redmirc
redmirc posted this 18 May 2016
Hi hella, thanks for your reply. I have anothet issue where the header picture is not being responsive on mobile devices. Why? Do i need yo use a particular plugin? Yhe website is www.climbing.com.mt
Support Team posted this 19 May 2016
I see the image resizing fine. Please attach a screen shot of the issue you see.
Hi, I see the image resizing fine. Please attach a screen shot of the issue you see. Sincerely, Hella
redmirc
redmirc posted this 19 May 2016
Hi hella,
I used the width =100% and height = auto and i am not sure if that is the correct code. Is it correct or i can find issues in the future?
Hi hella, I used the width =100% and height = auto and i am not sure if that is the correct code. Is it correct or i can find issues in the future?
That is the correct way to make the image fit the screen.
Hi, That is the correct way to make the image fit the screen. Sincerely, Hella
